Re: KiKat-4.4.2 for Minix X7
Originally posted by Molle View PostIs it possible to take a parameter file (e.g. a 2GB one) from another KK ROM (e.g. 'Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA') and use it with this ROM?
Sent from my Nexus 7 using Tapatalk900Supersport
freaktab developer
Originally posted by 900supersport View PostIts easy enough to make a suitable parameter file, if you post the current parameter file I can make some new ones with more app space.
parameter
Code:FIRMWARE_VER:4.2.2 MACHINE_MODEL:rk30sdk MACHINE_ID:007 MANUFACTURER:RK30SDK MAGIC: 0x5041524B ATAG: 0x60000800 MACHINE: 3066 CHECK_MASK: 0x80 KERNEL_IMG: 0x60408000 #RECOVER_KEY: 1,1,0,20,0 CMDLINE:console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00006000@0x00004000(kernel),0x00008000@0x0000A000(boot),0x00010000@0x00012000(recovery),0x00020000@0x00022000(backup),0x00040000@0x00042000(cache),0x001FE000@0x00082000(userdata),0x00002000@0x00280000(metadata),0x00002000@0x00282000(kpanic),0x00180000@0x00284000(system),-@0x00464000(user)
Originally posted by strix View Postare the new kernel in the rom or do i need to dowload the kernel to?
here's a few to try.Attached Files900Supersport
freaktab developer
Incredible fast ROM!!!!
Kitkat is so smooth... Mouse (A2) is smooth (so Thanks Minix for so crappy drivers!)
I had a forced reboot one time so far during Titanium restore.
For now i checked MXplayer with 1080p ... It's just PERFECT! in 1080p60hz... no need to switch in 24hz!
i will try xposed framework + gravity to see if we can tune this kitkat rom.
- nfs + init.d can't work... maybe it's me.
To be continue....Last edited by roolmapool; 11 January 2014, 23:27.
To be continue....
Sent From My Nexus 7 (2013) Using Tapatalk
Just installed this for testing. Ethernet works which is excellent.
BUT, I can't seem to install purchased apps from Play store. When I try to install e.g. MX Player Pro or External Keyboard Helper Pro, the process just hangs. If I then bring down the status menu and try to clear the messages, the device reboots.
Originally posted by Molle View PostJust installed this for testing. Ethernet works which is excellent.
There are currently 2142 users online. 2 members and 2140 guests.
