Originally posted by Molle View PostI get an "Error mounting /external_sd" with that as well. Within the OS the SD card works normally.
Guest
Could anyone give me a brief summary of which logs I can store and how?
I'm used to finding logs in Linux but in Android it seems a little different.
Logcat?
Where do I store the files and retreive the files?
Originally posted by brezix View PostTested both, OC i normal for X7. The same problem.
could someone reproduce this issue with latest kernel too?
Originally posted by wasser View PostAre you using my cwm reccovery which is included in 0.92?
Originally posted by Lelin View PostI have problems mounting external HDD 1T and USB stick.
Originally posted by Molle View PostThis ROM version supports mounting only one USB storage at a time (it's mounted on '/mnt/usb_storage'). In JB-based MINIX ROMs the first USB storage device is mounted on '/mnt/usb_storage/USB_DISK0' and so on.
OK. Thanks. Seems I have to go back to JB
So happy with this KitKat firmware and kernel
Wasser, Thank you for making KitKat 4.4.2 on the Minix X7 a reality. I successfully flashed it last night. This is the rom I will keep on this device and will flash new versions when features or bug fixes are added.
One thing I did see when running AnTuTu (19407) and the CPU-Z app. The screen resolution is being reported as 1920 x 1008 not 1920 x 1080. It does not seem to effect anything, but perhaps it was a typo in one of the config files.
Once again, thank you for giving us the latest version of KitKat so we can experiment on this Minix X7
Originally posted by georget View PostOne thing I did see when running AnTuTu (19407) and the CPU-Z app. The screen resolution is being reported as 1920 x 1008 not 1920 x 1080. It does not seem to effect anything, but perhaps it was a typo in one of the config files.
Originally posted by wasser View PostHi all
i uploaded new oc kernel with the following parameters:
CPU: 1008/1200/1416/1608/1800
DDR: 720
GPU: 400/600
Default governor: ondemand
Default i/o scheduler: noop
Enjoy!Originally posted by wasser View Postplease try this new kernel, it supports stock ir-remote
http://www.freak-tab.de/wasser/kernel-minix-x7-160114.zip
is it the same kernel?
Also, who ever is having issues mounting multiple external storage, try any 3rd party app, Paragon lets you choose the mount directory.
There are currently 2351 users online. 0 members and 2351 guests.
