I am on QS. I am a noob on build.prop. What do I have to change in the build.prop?
Guest
Re: UPDATE - Minix Neo X7 - wasser firmware 1.0.4 - KitKat Android 4.4.2
Originally posted by flhthemi View PostCould we modify the code or remove that line? Maybe change "rk3" and/or "neo-x" to " " ?
I don't know enough to even know what file that is contained in so I'm just taking a wild guess.
So yes, it is quite an easy fix if there is anyone there who can compile it for you at the moment.To Infinity and Beyond.... XBMC
Originally posted by ant View Post
BTW, I saw CMW-recovery.img in Wasser's ROM in system->vendor->preinstall. Wasser XBMC and ES File explorer are also present in same folder. Is it possible that CWM recover is already installed in wasser ROM?
Originally posted by Flumpster View PostI don't have the code in front of me now as I am on holidays but I removed that minix check in the new Beyond. If I remember right it originally checks if it is a OUYA and if it isn't it then checks if it is a minix. I just left the Ouya check there as it needed different encoding and made the minix check work for everyone else.
Thanks Flumpster!FLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
Originally posted by balaji View PostIs it possible that CWM recover is already installed in wasser ROM?
Originally posted by Molle View PostYes, it is.
@balaji - from the terminal type:
su
reboot recovery
That should get you to native CWMMinix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
Originally posted by wackidth View PostMolle redirected me to this thread. Because I have the same issue with SPMC and passthrough.
ro.product.model=NEO-X7-216A
so you could change to that or something that begins with "neo-x" because that's what koying test.
Originally posted by tampametal View PostI've played around with several versions of xbmc and in the short period of time with the Minix x8h what's the best xbmc to run on this device? I'm currently using minix Xbmc 13.3Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Originally posted by kianfra86 View PostAnyone could help me? The rom works so good but I can't install skygo with 4.4 android. The voodoo ota root keeper doesn't work with this android version, how can i do? Is there an alternative app as voodoo that it works with this android version?thx for helping!Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Guest
Sorry to hijack this thread again. As I am on QS.
But I still have no luck on changing the build.prop. For SPMC and passthrough.
Which Ro. do I have to change in rk3 and neo-x?
Originally posted by wackidth View PostSorry to hijack this thread again. As I am on QS.
ro.product.brand=minix
ro.product.name=rk31sdk
ro.product.device=rk31sdk
ro.product.board=rk31sdk
ro.board.platform=rk30xx
ro.build.product=rk31sdk
Originally posted by jmcm View PostI don't know for sure right now, but looked at some build.prop file i've found and it should be one of this:
There are currently 2621 users online. 1 members and 2620 guests.
