    Originally posted by lachyzee View Post
    Is there a post around that lists the main features of wasser XBMC v. SPMC/xbmcz etc?
    I've not seen a post with a comparison but....
    I'm pretty sure that wasser xbmc v1.3 is built using the latest source from spmc. So I can only assume they'll perform very similar depending on what additional tweaks wasser added / removed?
    I must say that wasser 1.0.4 and wasser xbmc 1.3 is an awesome combo.... dänke wasser!
    Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
    Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
      Originally posted by vab.android View Post
      Can someone post the mirror for the FW 1.0.4?
      The link in the first post is not working.
      Thanks,
      Vab
      I'm uploading to my media fire account now. It'll take about an hour. My upload speed is poor at best, sorry!
      Once uploaded I'll update this post with the link. Inside the zip is my file pack for the ROM so it contains the wasser 1.0.4 ROM, 1080 oc kernel pack and the RKBatchtool (no driver file, sorry) which I used to flash the ROM.
      Before it gets asked....
      Unzip the download first.
      Then unzip the wasser 1.0.4 file (this is the ROM).
      Then unzip the kernel pack if you have 1080p and want a oc kernel. (I use max oc kernel with zero issues)
      The RKBatchtool is already unzipped.
      Link to ROM:
      http://www.mediafire.com/download/sm...KBatchTool.zip
        I just upgraded from Wasser XBMC 1.2 to 1.3 and when I checked my audio settings in XBMC i saw that the channels selection tab is greyed out. I wanted to select 5.1 and I'm not able to. Did I do something wrong? I need passthrough to work on 5.1 channels.
        Thanks.
          Re: UPDATE - Minix Neo X7 - wasser firmware 1.0.4 - KitKat Android 4.4.2
          Thanks.
          If you have passthrough enabled, then you don't need to change the channels, because digital sound is sent to your receiver and is your receiver that do that job.
            (Link will be here when uploaded)
            What kernel do I get if I just flash the wasser1.0.4. rom as is? Should I download and flash the 1080p OC kernel to achieve 1080p resolution on my movies(played from external HDD in Mxplayer or xbmc streamed videos)??
            I also use this box to play 3D movies on TV and those are 1080p as well. Does the 1080p kernel make the whole rom show up as 1080p(I.e. chrome, gallery, other apps)? Will it make icons smaller on home screen?
              Auto hide
              Wasser, firstly thanks for your effort and releasing of version 1.3
              I tried it and found out that auto hide of botton line menu of the main screen does not work. In v 1.2 it worked well.
              It might be just my feeling but air mouse freezes more often during selection of any item comparing to v 1.2. Higher CPU load? (I am running it on HardwareGuru 5.0)
                I flashed wasser 1.0.4 and nothing more, and the kernel is 1080p in every apps. The icons is not smaller on home screen, the size is similar to icons on 720p roms. No problems so far, and xbmc (any version) runs faster when compared to minix jelly beans roms
                  Download link added to post #1802
                    Thanks for responding. I agree the performance is outstanding and the rom looks great on home screens and in apps. Xbmc clearly shows 1080p resolution in syatem info, but I wanted to be sure about the rest. I just wanted to make sure .
                    I had a lot of lag on minix 008 FW but found that if I waited it would eventually play the movie (or whatever function I was doing), but with Wasser 1.0.4 there is no lag and no waiting! I installed minix metro launcher.apk but Im using the provided "launcher3" which is awesome.
                    Now...if I could just fix my Onkyo AV receiver I could look at all this discussion about "pass through" but for now 2 channel is all I need.lol. Wasser you are the man
                      Link to ROM:
                      Thanks a lot,
                      vab
                        Can some one upload rkflashtool also? ;-)
                          Here they are, RKflashtool and the drivers. You have to unzip the download.
                            https://dl.dropboxusercontent.com/u/...KBatchTool.zip
                            Thank you! :-D
                              Hey guys,
                              anyone here using SpotiMC? I can't get it to work on Wassers XBMC 1.3 (or any of the previous versions), always the error is "unable to find 'libspotify'". Any known workaround?
                                wasser-xbmc-1.3 feedbacks
                                Ĥi all,
                                please test passthought in wassser-xbmc-1.3 and give me feedbacks. I have seen some reports about crash in wasser xbmc 1.3. Does it appear in spmc?
                                thanks
                                wasser
