Originally posted by ilovemymac View PostMaybe i missed it but how do you flash these OC kernels to this firmware? Im use to using quick flasher and that doesn't work here.
Can someone help?
If you need the 1.0.4 stock kernel I posted a link half way down page 93.Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
External DVD
Originally posted by berrani View PostIs there someone using a dvd-rom usb external drive that works with wasser firmware?
thanks
Matt
Originally posted by Bazmamfoo View PostI've been told that this ROM will run on my Ugoos UT2 but will it cause an issue that my device is 32gb?
Sent from my SM-G900F using Tapatalk
Just a reminder, if you go from JB to KK and then want to go back to JB there are particular steps you need to take to get JB back or you may brick your UT2.
This is whats been holding me back from moving to KK.FLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
Re: UPDATE - Minix Neo X7 - wasser firmware 1.0.4 - KitKat Android 4.4.2
Originally posted by flhthemi View PostThis is a question I would also like to see an answer to. Also how are ROMS with parameter kernals, like Finless, going to install on a 32gb UT2? Common sense tells me NOT.
Sent from my GT-P5100 using Tapatalk
Bluetooth Timeout causing streams to freeze / pause.
Thank you Wasser for all of the hard work that went into this firmware. Prior to the install of your firmware and kernel my x7 was pretty much unusable. I've searched and couldn't find any information or fix relating to the problem I'm having.
For some reason whenever either of my Bluetooth remotes/keyboards timeout, anything that is being streamed such as YouTube, XBMC or Netflix stops.
It's really strange. Even if I manually power-off any of my Bluetooth remotes during a stream, the stream stops instantly.
If anyone knows of a fix or a workaround for this problem it would be greatly appreciated.
Thanks again.
Originally posted by swiftscsi View PostThank you Wasser for all of the hard work that went into this firmware. Prior to the install of your firmware and kernel my x7 was pretty much unusable. I've searched and couldn't find any information or fix relating to the problem I'm having.
Thanks again.
Can you test using your MiniX connected using a wired Ethernet connection?
Originally posted by cyboy View PostHello guys
There is a new version of spmc with too many fixes include the passthrough fix for minix.
I tried that version and still passthrough is not available. I have to use again the buildprop to modify the file?
thanks
Good Luck
There are currently 1867 users online. 2 members and 1865 guests.
