One more quick question folks - is there a way to enable/configure daydream/screensaver/standby function in this firmware? In short - I'd like my box to go black screen in a minute of inactivity and go to standby in 10-ish minutes (if possible at all).
There's a Daydream section in options, but it doesn't seem to work in any configuration (clock/photo frame) and with any pre-defined timeout.
Your advice please?
Thanks!
Originally posted by Casterina View PostIs this mod based on the 1800mhz overclock kernel?
Originally posted by Casterina View PostI have flashed kernel and boot.img using terminal but how do I know that its successfully flashed? All I get is wrote kernel and boot partition
Tried to flash kernel and boot.img with RKAndroidTool but got error,
Reboot
Get AnTuTu from "Google play" and run a Benchmark to see CPU speed..
Originally posted by Phycopat View PostThen output from terminal is "wrote kernel partition" and "wrote boot partition" its done! :-)
Reboot
Originally posted by Phycopat View PostGet AnTuTu from "Google play" and run a Benchmark to see CPU speed..
Originally posted by xmnemox View Posti have some problems with this rom... i have a minix x7.
after a while appear a message.. "google play store closed in bad way" (i'm italian)...
after a while the virtual keyboard in xbmc doesn't work
when xbmc is scanning files and scraper my minix reboot...
why??what problems could be?
my advice ->> reflash with wasser kitkat 1.04,then deinstall wasser and try kodi helix.
give it a try ^^
-->>>>> http://www.freaktab.com/showthread.p...-A-little-Help
Thank you guys.
Wasser's KK 1.0.4 with Molle's boot image and OC kernel config. + Karel's Kodi-Helix seems to be the winning combo for me.
Played fluently blue ray iso (from external media drive) with dts 5.1(optical). And no more endless buffering in xbmc when watching online movies.
I have almost gave up on my Minix (and in general on android TV boxes) and was thinking of getting a Lenovo Q190 with i3 processor, but now I think I'll save the cash and keep the Minix.
Hi Mole,
I hate to sound like a complete noob, but what command are you using in Terminal emulator to flash your Boot Image?
we are using this for the kernel...
flash_image kernel /sdcard/kernel.img
Would it be?...
flash_image boot /sdcard/w104_mali_boot.img
or should I rename "w104_mali_boot.img" to just "boot.img" ?
George
George
su
flash_image boot /sdcard/boot.img
Would it be?...
George
Originally posted by xmnemox View Postwhere I can fine the kernel with stock clock?
in this moment I'm using washer with oc kernel-minix-x7-ddr800-gpu798h-1080p but isn't stable... i like very much washer firmware, so I want to try with stock clock!
10x a lot
There are currently 2778 users online. 1 members and 2777 guests.
