    Hello everyone
    Could someone please clarify whether passthrough audio works on this build? I have seen some varying reports on this thread. Thanks!
      Originally posted by hreich View Post
      I am having problem..when using vpn i cant connect to internet...two weeks ago it worked perfectly
      try to set the VPN using the software VPNroot (available on play store), I don't know why, but with this app VPN just work.
        Hello everyone.
        Has anybody managed to get openvpn working on this rom? It connects, but it seems that no data are apssing through the tunnel, so it seems that I don't have internet connection.i tried several apps.
          Hello, im just trying this rom on my MK 802 IV, its work at well, but bluetooth didn`t work, i have realtek version of WI-FI. Pls help!
            Originally posted by Molle View Post
            Search a bit within this thread and then use RKDevelopTool v1.37.
            Hi Molle, I have found how to install the kernel, but I don't find the program RKDevelopTool v1.37. Can you give me the link?
            Grazie
              Download e.g. Finless v1.9 ROM for the X7. The tool is included.
              NVidia Shield TV 2015 16 GB || Stock
              NVidia Shield TV 2017 16 GB || Stock
              Buy me a beer?
                Thank you very much
                  The X7 has a Broadcom chipset so, naturally, there's no Realtek driver in the X7 kernel. You can either accept this incompatibility or switch back to a ROM specific for your device.
                  Buy me a beer?
                    Hi Molle, I have found tool ROM_Flash_Tool_137. Is it??
                      Hi! But I used the ROM for x7 based on 4.4 and in it bluetooth worked fine. In 5.0 it is impossible?
                        I guess only wasser knows the definite answer to that. It all depends on the kernel configuration. Some custom ROMs package more stuff to the kernel than others.
                        BTW: Which KK ROM did you use?
                        Buy me a beer?
                          Now I'm using Neo Official Release X7 Kitkat 250 ( february 8th 2016 ).
                            That's the one.
                            Buy me a beer?
                              Is there a way to downgrade from this Wasser 3.0.6 Lollipop to oficial KitKat 250. I flashed this Wasser rom and i'm not happy with the way it behaves : no remote apps work like CetusPlay,Yatse, i have problems with screen etc.
                              I like to know if it's possible to downgrade. Thanks in advance.
                                Hey guys. Know someday what's causing this?
                                Sent from my ONEPLUS A3003 using Tapatalk
