Originally posted by gromila31 View Post
I still do not understand what a breakthrough). except for the name "lollipop"
Originally posted by flhthemi View Post
I think it's already rooted since the very 1st release:
Version 3.0.0- firmware based on lollipop 5.1.1
- support HDMI sound, SPDIF and HDMI Bitstream
- ir-remote support
- support ethernet
- support wifi
- support bluetooth
- support LED
- init.d support
- unified single partition
- sdcard support
- webcam support
- nfs filesystem support
- ntfs filesystem support
- exfat filesystem support
- iso/udf filesystem support
- xposed support
- added hide/show navigation and statusbar
- added poweroff button in navigation bar
- added softreboot, reboot in recovery and bootloader
- added "clear all recent apps" button
- add support hdmi virtual switch
- multiuser support
- root device
- A2 Airmouse support
- hardware keyboard support
- lock screen support
- add latest google apps
- added menu option for "Connect to PC"
Personally I need my X7 not to be rooted! Please can someone explain how to achieve this, UNROOT, as it isn't very clear.
good afternoon. installed firmware, all right, but there is one thing, the system does not determine the size of external hard drive are 250GB hard drive, the system determines 0gb, respectively, there is no way to put the cache. Do you expect further changes?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hi, first thanks for this great rom android 5.1, very happy.
I have found two things:
1. The app Firefox causes that it restart the Minix
2. The app RKRemoteControl not see Minix.
I'm using version 3.0.6
Originally posted by Bazmamfoo View PostI see "Xposed Support" is listed as one of the tweaks of this ROM. Does that mean that the ramework is already in-built and we can just get the Xposed Installer apk?
[UNOFFICIAL] Material Design Xposed Installer [26/11/2016] Xposed General
Originally posted by Danilasib View Postone more thing. you need to do to connect the USB Modem? ppp widget via modem 3g network connects but minix Internet does not come out. in the settings tab there is not "mobile networks" that can be taken in this case?
I also have a USB SIM modem. The PPP Widget is managed from the widget, not from the system settings.
I have now tested the PPP Widget 2 and 3, I have not got it to work on this ROM. With the kitkat version worked.
- ir-remote support
- support ethernet
- support wifi
- support bluetooth
- support LED
- init.d support
- sdcard support
- webcam support
- xposed support
- multiuser support
- root device
I know my friend it's rooted but some apps need to be unrooted to "work"!
so a root.zip and an uroot.zip would be very helpfull for these situations !!
so a root.zip and an uroot.zip would be very helpfull for these situations !!- add menu to root/unroot device
In fact I'm looking for solution for showmax, Anyone knows another hack then just unroot?
There are currently 2758 users online. 1 members and 2757 guests.
