Originally posted by enboig View PostThinking of installing it, when upgrading from 3.0.6 to future 3.0.7 would my data be lost?
Originally posted by flhthemi View PostHey Molle, if I flash the 1800 kernal do I lose any data?
Hi I have install the 3.06 and works but now I have every few sec a screen flicker
try to install the kernel-neox7-wasser-cpu1800-ddr800-gpu798-hdmi_flicker but I can"t load the file (load firmware failed ) white all kernel files am using RB batch 1.7 and 1.8
Can anyone help me pls
greeting
Originally posted by henk32211 View PostHi I have install the 3.06 and works but now I have every few sec a screen flicker
greeting
Download the finless ROM from HERE. Unzip it to a location of your choice. Delete the folders "Drivers" and "FinlessROM" you don't need them. Now you should have 6 items left in the "T428 4.4.2 Finless 2.0" folder.
Folder - Language
Folder - Log
File - config.cfg
File - config.ini
File - README FIRST.TXT
File - ROM_Flash_Tool_21.exe
You should have all the drivers installed on your PC so that when you connect your box the RKBatchTool.exe sees it. This is run just to confirm you have the drivers installed and they are working. You need to see that green box light up. If it does you're good to go with the ROM Flash Tool, so just close the tool if it identifies your device. If it doesn't you need to install the drivers and get them working so that it does.
Once you have it working open the ROM Flash Tool (I use ROM_Flash_Tool_21.exe).
You need to be on the "Download Image" tab.
Untick ALL the boxes.
Item #4 should be "KERNEL" at the end of that line (to the right of the path to the kernel) there is a blank box. Click inside it and load your desired kernel image using the pop up window.
Make sure after it loads it is correct and make sure the tick mark is showing.
At this point I don't know which of the 4 buttons to click Run, Switch, LowerFormat or Clear. *I* think it's Run but until someone who KNOWS (Molle maybe?) don't even think about doing anything because you might end up with a brick. We don't want that. So when someone with more knowledge than I comes along and gives us the answer I will edit this post and we'll move on. If I'm completely wrong I'll just edit this post and delete it all.FLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
Originally posted by henk32211 View Posttry to install the kernel-neox7-wasser-cpu1800-ddr800-gpu798-hdmi_flicker
I use Windows 7 to do this. I don't know if Windows 10 can do it as I have never tried. So....
Folder - Language
Folder - Log
File - config.cfg
File - config.ini
Originally posted by Molle View PostI'm pretty sure the extra kernel only adds higher operating frequencies for the CPU, RAM and GPU. Most likely it won't help with any flickering issues. I have never experienced any, so YMMV.
1 I think I did something wrong the first time by flashing 3.05 it did"t work
2 power off and power on flash mode get green box try to get back to 240 minix firmware get pink box
3 power off power on flash mode get green box flash wasser 3.05 and it works no error
4 flash to 3.06 working no error but get screen flicker
the rest working well
I think I broke it????
BUT no less many thx from me with all support from all of you guys
There are currently 3527 users online. 0 members and 3527 guests.
