    Hello
    Has anyone else faced boot loop and black screen after fully unroot the device(from su)?
    Update : I figured up and found that uninstalling busybox was the problem!
    In matter of fact it has 2 busybox installed !
    And when i erase them oops : boot loop and black screen !
    Any ideas?
      Hi I like this rom but I have a small problem.
      A 250gb samsung ssd is reported wrong in solid explorer, its the fourth one in the list 847mb free of 847mb?
      The device works as expected on a minix u9 running the stock firmware
        Hi guys, thanks for the wonderful Rom.
        I cannot set a VPN. Even if I set a PIN, the VPN seems to connect but I have no data transfer.
        Someone else encountered this issue?
        UPDATE
        Just for future reference, I connected to the VPN using VPNroot app, that allows to connect without using the PIN.
        So, somewhere there's a bug, but I honestly cannot figure out where it is.
        Thanks again!
          Hi I am using the 3.06 rom and am having weird issues with an 250gb external ssd.
          it shows space available on a minix u9 but on my x7 846mb free of 846mb where it should be 846mb used of 250gb
            ive started using this rom....but after 10 !! crashes within 1 hour i went back to official 250
            the rom looks nice but too many crashes :C
              That's unfortunate. For me it was always perfectly solid, even with the oc'd kernel.
              Did you use 'Update' or 'Restore' option in the batch tool when you installed the ROM?
              NVidia Shield TV 2015 16 GB || Stock
              NVidia Shield TV 2017 16 GB || Stock
              Buy me a beer?
                Running very stable also for me also, and that's 2 boxes running 24/7
                  I am having problem..when using vpn i cant connect to internet...two weeks ago it worked perfectly
                    I have installed 3.0.6 version + oc kernel. After one month i have had some minor issues:
                    - Some unexpected reboots.
                    - Some display problems (hdmi signal gone).
                    But the most annoying bug it is kodi related (kodi 17.3/17.4):
                    - Audio sync problems with local or remote files (direct download or torrent -quasar addon-). On MKV, AVI or MP4 files.
                    According this link [https://forum.kodi.tv/showthread.php?tid=308496 ] it's an underlying problem of android + kodi. But the workaround (notsoshitty and disable HW acceleration) doesn't work.
                    Anyone notices? Another workaround?
                    Best regards and thank you sir wasser and sir @Molle
                    PS. With other players (MX player) there aren't sync problems (on local files).
                      Try spmc latest alpha
                        I did experience audio sync problems in SPMC with multi-channel mp4 files. I didn't find any other workaround except to set the audio offset to -0.250s for each individual video.
                        On files with just stereo soundtracks, the sync was spot-on.
                        Buy me a beer?
                          Hi sir EagleEyeXZ and sir Molle,
                          I have tested the alpha 8 [http://download.semperpax.com/spmc/a...rmeabi-v7a.apk ] but unfortunately it is the same behaviour. Audio is not sync. :-(
                          But sir Molle was right, with stereo files there is not sync problems (nor on kode and nor on smpc).
                          It's a pity but as far as I know it's NOT related with this rom.
                          Regards
                            Indeed it is not. I'm currently using an NVidia Shield w/ SPMC-16.7.1 as my main media platform and the same audio sync problem affects all multi-channel DD/DTS videos.
                            So, evidently, it's a problem in Kodi/SPMC. Fortunately SPMC remembers the offset settings for every file, so I need to set the audio sync just once for each new video with MC soundtracks.
                            Buy me a beer?
                              Hi, I don't know how to install the kernel img. I have to use the tool RK or the app into the box ?
                              @ Wasser :Thanks for all the job that you do for us
                                Search a bit within this thread and then use RKDevelopTool v1.37.
                                Buy me a beer?
