I'm using version 3.0.6. The app RKRemoteControl not see Minix. I have spoken with some users and they said the same. Could you fix it? Thank you!!!
Originally posted by Bazmamfoo View PostI seem to have lost root somehow, anyone know what may cause that and how i get it back without reflashing? Was working fine a few days ago
Originally posted by Pluto View Post
What is wrong expressing gratitude and surprise, especially for a device whom its manufacturers did a worse job the this cooker right here, let alone that all expectations for the X7 have long been laid off. Kitkat was struggling with a lot of apps that i use, considering how good Lollipop is in this case...so yea, it is a breakthrough...from where we stand.
Don't lose precious time of yours and spare the internet a few bytes of traffic please, your comment was a lot less needed then my expression of happiness that i am getting a major version increment.
@ all root users having issues hiding root from apps, there are several Xposed Modules to hide SU, and many of them are good as they hide from "bank apps", which logically should use tighter security.
Originally posted by gromila31 View Post
Of course, your comment here is the most precious
I don't know where you're from but that's considered bad manners anywhere I've ever been.
Originally posted by minixfreak View Posti really admire this box finally get some love but its useless if sound not properly working .... anything to do with kodi has sound issues cuts in and out .... tried multiple builds of kodi and still same issue could u please fix or make a custom kodi that will work properly .... all i did was test kodi ... could be possible its happening in youtube etc ....
Originally posted by welcometopoland View PostPlease advise on how to flash the custom kernel .img?
- use Android Tool and select kernel only ?
Originally posted by Molle View PostThis method was the only one that worked for me with this ROM version.
By any chance, does updating the Busybox bultin with the one in playstore mess things up?
EDIT:
So far, i've hit a few obstacles.
1. Wi-Fi Region Code change made the system unbootable, not sure why.
2. Kernel Adiutor, i did something at the end, after renaming the hostname, i think i viewed a tab, and it just snapped and never made it to boot again.
3. Whatever kernel tool, setting min freq to 1ghz does not stick, which i think is crucial for smoothness.
Updating Busybox for some reason ends up catastrophic too, and tbh i dont even know why i've updated it, just noticed quite an old release.
Updating to SuperSU-2.79-SR3 is not advised too.
Xposed installed fine from dvdandroid's installer.
EDIT2: Screenies
Hi everyone and a big thanks to Wasser for his great rom.
I installed this rom yesterday and almost everything seems smooth and no major issues experienced so far. Anyway, one... two indeed are the bugs (issues) found:
1) the most annoying one: sound disappear while looking at a movie and, in the meantime, the info bar at the bottom of the screen start flashing as to alert you that something is going wrong. This issue can then be fixed by opening the audio menu while watching the movie and selecting or deselecting the "stereo upmix" item in it. Sound is then audible again and no more flashing of the bar at bottom!
2) when going back from movie library to home screen, all the system hangs. It does not respond to the remote control for a while, as if the system was busy. After about 20 seconds or more everything comes back as normal.
Is someone else experiencing the same issues?
There are currently 2672 users online. 1 members and 2671 guests.
