Just to spare anyone with similar needs the trouble: I installed successfully 3.0.6 in my minix x7, but when pairing with any bluetooth accessory the whole device crashes (kernel?) and it has to be powered up again. It is a deal-breaker for me as I need bluetooth audio, so I reverted to stock kitkat.
Originally posted by gandolfi View Posti don't know how to flash kernel. Flashtool don't work because i can't read the image....
(This is getting ridiculous. The same kernel flashing questions get asked on every fscking page.)
Je remercie énormement l'auteur. Mais il me parait légitime, de mettre en premiere page, les instructions pour flasher le kernel fourni. On est pas tous des informaticiens aguerris. Et se lire 178 pages pour cela c'est pas forcément utiles.Originally posted by 2wheel View PostShould put the whole 178 pages in the first post them I guess
Â*
The first page is made to have a summary of the tricks of the forum people.
wasser are you planning to finish this project or is this the end of it? Its working very smooth allready. I only cant use rk.frequency switcher on kodi 17. It says frequency switcher does not work on linux2 its needed to switch on MediaCodec. The rom is great and no audio passtrough is for me not a big issue
Originally posted by gandolfi View PostBut it seems to me legitimate, to put in first page, the instructions to flash the supplied kernel. We're not all seasoned computer scientists.
Hi there!
This one is for Molle and wasser ,
I know thats probably asking way too much, but is there a possibility to compile the oc kernel for the AP6210 wifi chipset, so I could test in other devices the RK3188 lollipop rom.
Or if you can share source I can try to compile a kernel for the rk3188t with AP6210 wifi chipset;
Mine mk908ii is running even more oced than your´s oced kernel so I don´t think frequencies will be a problem.
I did test an other lollipop rom on my Tronsmart Mk908ii, but was it unstable and had no bluetooth support.
An other thing is have you tried magisk for root? It only supports LL and up, I´m using it on N roms with great results.Last edited by Babaum; 13 July 2017, 13:44.
There are currently 2245 users online. 1 members and 2244 guests.
