Have you also tried to use a different HDMI cable? It's not likely but worth a try. Oh, and maybe try changing the display settings to a lower resolution? Like instead of 1920X1080 try the next lower one and see if it's gone...I don't know if the X7's do that. Or maybe mess with the TV itself or a different TV or A different HDMI port.
FLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
Originally posted by konnichiwa View PostHi, Can I flash this rom on minix V7 mini ? I want run lollipop on my V7 mini. Thanks
Originally posted by henk32211 View PostI think I broke it????
Originally posted by flhthemi View PostHave you also tried to use a different HDMI cable? It's not likely but worth a try. Oh, and maybe try changing the display settings to a lower resolution? Like instead of 1920X1080 try the next lower one and see if it's gone...I don't know if the X7's do that. Or maybe mess with the TV itself or a different TV or A different HDMI port.
Yes its working great now many thxLast edited by henk32211; 08 April 2017, 09:30.
Even the tool in Finless rom does not seem to work with me. All i set is min freq to 1ghz, altough sub1ghz frequencies are being used, and 1.5 and 1.6 barely make it above 2-3%. 1.7 and 1.8 remain unused.
I surely know i dont have the rk3188t variant as i have OCd this one before with the same rom.
just in case, have you guys flashed the kernel together with the rom or after?
EDIT: attaching a catlog, not sure if helps but...Attached FilesLast edited by Pluto; 10 April 2017, 17:30.
Originally posted by Pluto View Postjust in case, have you guys flashed the kernel together with the rom or after?- Start RKDevelopTool
- Connect device
- Erase IDB twice
- Disconnect / power off device
- Start RKBatchTool
- Select ROM image
- Connect device
- Flash ROM with "Restore" option
- Select partitions and images
- Connect device
- Flash images
- Connect device to TV etc, and power on
- Profit...
Can anybody point me to a nls_utf8.ko kernel module, which will work with the kernel in Wasser FW 3.0.6?
I did a clean install of version 3.0.6 and I'm trying to mount a share via CIFS, but utf8 doesn't seem to work. "mount -o iocharset=utf8" results in "cannot access a needed shared library". When I remove the iocharset=utf8 option, everything works fine, but then some of the file names aren't displayed correctly (I get only question marks). I realise that the kernel is not configured with nls_utf8 and that's why I'm looking for a nls_utf8.ko module, which I can load before mounting a CIFS share.
There was a nls_utf8.ko module posted in this thread for an older version of the FW, but I cannot find such module for the 3.0.x series.
Any help is much appreciated! Thanks!
I have managed to solve the utf8 problem by compiling the module from the kernel sources mentioned in the topic 3.0.101 Kernel Released. I am attaching the file, should anyone else be facing the same problem.
On a side note automatic frame rate switching doesn't seem to work in Kodi. I can confirm that it works when a video file is played directly from the pre installed file manger app, but in Kodi it doesn't work.
I seems that Kodi 17 doesn't support rate switching on Rockchip any more, but at least Kodi 16.x looks for the file in /sys. It just happens to use a different path, which results inCode:ERROR: RKEGL: no rw on /sys/class/display/display0.HDMI/mode
Code:/sys/class/display/HDMI/mode
Is there another way to work around this?Attached Files
Originally posted by Molle View PostI usually flashed the ROM and the additions back-to-back. First the ROM with RKBatchTool, then the oc'd kernel (and my modified boot image) with RKDevelopTool. Here's the complete procedure:- Start RKDevelopTool
- Connect device
- Erase IDB twice
- Start RKBatchTool
- Select ROM image
- Connect device
- Connect device
- Flash images
- Profit...
Is that the same boot.img that you've shared quite a while ago?
There are currently 2788 users online. 1 members and 2787 guests.
