Thank you, the Kernel you supplied seems to be doing the job with 3.0.5. I had one reboot which occurred after I installed and set a live wallpaper (Asteroids Pack). I removed the live wallpaper and it has been running 52hours without hiccups.
Hi guys,
I have got minix x7 with X7 Kitkat 250. I want to update x7 to wasser 3.0.5 in order to use kodi 17. I have got wasser-3.0.5-minix-x7-rk3188.7z, kernel-cpu1800-gpu798-ddr800.7z and RKBatchTool.zip files. These files are enough or not?
Normally i know to connect x7 to pc and install firmware. But up to now i didnt use any kernel cpu1800 file. Is it possible to explain how to install wasser 3.0.5 from X7 Kitkat 250 step by step?
thanks in advance..
thanks in advance..
flash the rom as usual with rkbatchtool (hit restore ) .....the kernel is optional since the rom image already has one...if you need to Overclock the cpu then you have to flash the kernel provided .. to flash the kernel image you have to use AndroidTool .. open it an you will see all partitions...check "kernel" , enter the kernel's path and hit "run" ..
Originally posted by skazza View PostHi all, i would to flash this rom but i have some doubts.Any feedback about this rom? Are there random reboots o freezings? Which kind of benefits i get flashing overclocked kernel?
Thanks.FLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
Originally posted by leerock79 View PostAnyone tried kodi 17 with this firmware?
I ve got choppy HD video playback and hicups
but also audio sync problems
There are currently 2161 users online. 2 members and 2159 guests.
