Hello guys
Its a long time ago, i flashed my Minix Neo X7, so i need some help
For about two years i have the RoDiSTe Rom installed, and today i want to test the Wasser 2.0.3. So i connected everything and run the Rookchip Batch Tool v.1.8
unfortunately i became an error(see Attachement) so what do i wrong?
[ATTACH]n519157[/ATTACH]
Has anybody else experienced regular dropouts in multi-channel soundtracks with Kodi-15.1 when using passthrough? SPMC-14.2 works fine but with the new Kodi DD/DTS sound drops out every 4-5 seconds like a clockwork.
Edit: Seems to be a common problem with Isengard builds and passthrough.Last edited by Molle; 21 August 2015, 08:34.
Guest
Originally posted by Molle View PostHas anybody else experienced regular dropouts in multi-channel soundtracks with Kodi-15.1 when using passthrough? SPMC-14.2 works fine but with the new Kodi DD/DTS sound drops out every 4-5 seconds like a clockwork.
I have in Kodi 15.0 and RC and beta xxxx, experienced continuous small drops like with 1-2 minutes intervals, the drop is less than half a second, very minor but anoying. It is during streaming (ice, phoenix for example)
i have SPDIF to Sonos bar, sub and P1´s. (simultainously with HDMI audio for TV (in case i dont bother loud audio)
I dont see a specific pattern, other than it feels like it is ALL audio streams.
This works fine from Apple TV + Netflix and my SAT receiver, so it is NOT sonos.
I will test movies from Harddisks later today. both DD 5.1 and other AC3´s... and simple stereo.
Hello Wasser
I was using a previous Wasser firmware (I cannot say which one...sorry). Now I've update to the last 2.0.3 . This ROM is working very good! My greatings.
But, there is one things not working respect the previous... :-(
I've an external bluray writer, the Samsung SE 506-CB that it was perfectly working before. This device is not normally recognized once connected to Android devices. It is necessary to keep pushed the eject button for 3 seconds, and the device will be recognized as a USB storage.
Unfortunately now with the 2.0.3 release, it is not at all recognized. Nothing happens by pushing the eject button.
This Samsung device is designed to work with: Samsung Smart TV, Android tablets and smartphones, PC.
May be I only have to ugrade the kernel?
TX to all
I am getting irregular sound drop outs when using spdif when using youtube, mainly use it to play music. I have had other sound issues when using kodi 15, so I am staying with spmc 14.2. Only way I can use youtube without sound drops is by just using the hdmi to my tv then sending the signal to my amp with component leads. It's just a pain as I like to leave my sound settings in Android on spdif for when I use spmc kodi 14.2
kernel-neox7-wasser-cpu1800-ddr800-gpu798
how can I update this kernel separately, onto the installed firmware (2.0.3)?Last edited by moksel; 01 October 2015, 12:42.
There are currently 2621 users online. 1 members and 2620 guests.
