Can anyone please summarise the best combination of ROM (obviously this one) + KERNEL + RECOVERY and General Parameters and tips?
I have been away for quite a while as i have been superbusy, and a month after flashing v2.0.3 with TWRP and OC Kernel, it started to have very weird issues, loads of FC's and a lot of reboots during booting procedures, and many times it wont make it to homescreen without 3-4 reboots (which it does by itself).
Originally posted by Pluto View Posta month after flashing v2.0.3 with TWRP and OC Kernel, it started to have very weird issues
Originally posted by moksel View Post
how can I update this kernel separately, onto the installed firmware (2.0.3)?
Code:flash_image kernel <path_to_kernel_image>
Originally posted by raven428 View Posthello. how to remove icons from desktop on this firmware? I am picking icons by fly mouse, but only able to move it: no "x Remove" appearing like on my android phone.
Try e.g moving the icon over the top (or other edge) of the screen.
Originally posted by Molle View PostTry with the stock kernel (see post #1). If the system remains unstable, I recommend a full reflash. Recovery doesn't play any role here.
Im doubting on SuperSU, when i get rid of superuser, the issues start to rise
Hi, I'm new on freaktab and I'm need little help. I have official firmware kit kat and I try change for wasser firmawre 2.0.3. Please tell my how I can do this ( step by step) and please tell my I'm should install all file (asser firmawre 2.0.3 after this oc-kernels and also stock-kernels??) ?. I try find answer in previous post but I have not found enough help. Thanks for help
I have come to the conclusion that my random encryption problems were a precursor to a hardware failure
as the Neo X does not boot at all now.
Having opened it up I see there is a small battery inside, could this be the problem?
I am not sure if I can replace it as the connections are welded, but worth a try I guess.
There are currently 2658 users online. 1 members and 2657 guests.
