Originally posted by EagleEyeXZ View Posti also try kodi 17rc3 no audio passtrough just noise... but videoplayback is just fine
Originally posted by LCBXX View PostMy X7 doesn't like this Firmware at all. After Flashing 3.0.5 it starts the random reboots even quicker than with 3.0.4. I suspect my X7 is borked.
How will I install this using RKBatchTool 1.8 - thus fat it is the only one working for me using Windows 10 Quickflasher does not detect the Minix on Win10
Originally posted by wasser View Postcould someone please test SPDIF passthrough in 3.0.5 and give me feddbacks? Please make sure that you download the firmware again because i uploaded new 3.0.5 firmware yesterday again.
Thanks,
Wasser
how are we supposed to install the OC kernel images?
also when i press the "windows" button on my keyboard my minix goes to sleep ! is that normal?
thank you
He wasser tested rkmc build from jan 6 2017.. no audio passtrough just loud noise... the .cpp files on official kodi 16 build detect ac3 or dts you only get hickups maybe a special kodi build is needed with a little patch.. if there is something to test let me know. On the weekend i will search spdif cable so i can test for you
Originally posted by EagleEyeXZ View PostHe wasser tested rkmc build from jan 6 2017.. no audio passtrough just loud noise... the .cpp files on official kodi 16 build detect ac3 or dts you only get hickups maybe a special kodi build is needed with a little patch.. if there is something to test let me know. On the weekend i will search spdif cable so i can test for you
gromila31, LCBXX, i have new kernel which should fix your reported issue. Please test and give me the feedbacks. Thanks
http://www.freak-tab.de/wasser/kerne...-fix-crash.img
Wasser
Wasser, thanks for new kernel. Problem of reboot and sleep mod is solved! But torrent tv video is bad - all in "pixels" and picture dont expand on full screen (use mx player, but not him problem).
There are currently 2089 users online. 0 members and 2089 guests.
