    Originally posted by ngoal View Post
    He mentioned it in the unoffical ouya forum. The problem lies with the software that was used to encode the videos. Koying has fixed this bug. I tried a couple videos I knew of that had this issue and they all work now. Try some for your self and see. IN my experience it was a rare bug and I can only think of a few videos that had the issue to try.
    Here's the change log for the new version. The issue was with videos riped with makemkv software. Koying has fixed this. No other version of xbmc has this fix yet.13.2.1 (2014/07/16):
    • New graphics (thanks to @Tinwarble from OuyaForum)
    • Register as launcher
    • Important fix for some MakeMKV et al 1-to-1 BD rips
      I can confirm ! !
      this is THE first gotham that plays beyond 10 min on certain hd material
      fkn awesomeness thx for sharing
        So
        Sorry for not trusting you at the beginning, apologies from my side to you; I had wasted a lot of my time before with this problem, for that I had been so incredulous; I had taken the time to install this version and set up all of the addons, and you are correct the HD content with problems on the official XBMC, Minix XBMC & Wasser XBMC had been corrected here on this latest SPMC_13.2.1. I had tested 4th examples with problem on IceFilms and Mashup-VIPplaylist-->Daemon88 and all of them are Ok now on this version.
        Unfortunately the happiness is not complete because in this version the subtitles (from different addons-sources) are not working; We need the subtitles at home. And for any reason I can remark that the image playing the content through this spmc version looks darker than in the original gotham, however I use screen adjuster apk set contrast to -40 on both here is not that effective as in the original. If you are reporting to the ouya forum it will be nice to let know koying that the subtitles are not working.
        I´m not using passthrough, but sure it will be good to get fixed the passthrough problem as well.
        Thanks ngoal.
        Anyway, it´s very strange that if koying had found the root of the problem this had not been implemented in the latest gotham 13.2 beta1; hopefully in the upcoming updates will be implemented on the official gotham and keep the fixes for the future releases.
          Originally posted by BTR11 View Post
          So
          Thanks ngoal.
          Just checked a video with the open subtitles add on and it worked fine. What add-on are you using for the subtitles? There is not one loaded by default.
            I´m using by default opensubtitles.org; but as well I had tried some others like subscene, podnapisi, and others. The subtitles are found and supodsely loaded, but are not being shown on the movie or the video; there are not error message just simply not being shown.
              strange I don't have this issue. does anyone else? I also have noticed no darker picture with spmc over xbmc
                Opensub worked at my setup on "Noah " for test in mashup/demon88/1080p
                  If you use spmc on your x7 this problem is fixed. Don't assume that you know everything. I've tested it on multiple android devices x7, nexus and ouya. I used any video i could think of with this error to test on my x7. Videos that freeze at the 10 min mark using wasser xbmc play fine on the newest spmc. Unfortuanately passthrough will not work however. Wasser maybe you could look into combining your passthrough hack into spmc?
                  For those who want to try for themselves go to http://spmc.semperpax.com
                  There is also no frameskips when using medicodec acceleration on this version
                  BTW awesome rom Ive tried them all and yours is the best one I've used. Simple and functional
                  i'm working new wasser xbmc which will include the fix for this issue. Thanks for your info
                  wasser
                    Hi, Wasser
                    What about wasser firmware for Minix Neo x8?
                      wasser
                      No 1
                      a question for you wasser: can you eventually implement:
                      mashup repo
                      fusion repo
                      opensubtitles & subscene
                      hybrid repo skin by mudislander - for more confluence user control and widgets would be cool and usable
                      That would make this ROM combined with your XBMC variation the final killer
                      I smell another donation coming
                        Originally posted by Theklavej View Post
                        No 1
                        mashup repo
                        fusion repo
                        also + from my side ^^
                        these repos are a must have oO
                        they are included by default in bxbmc so it would be very nice to have it in wasser xbmc.
                        and maybe you can try to use the spmc
                        as far as i can see its a little bit better with hw acceleration oO
                        maybe worth a try ^^
                        Semper Media Center (SPMC in short) is a android-minded fork of Kodi, by the former Kodi android maintainer, Koying
                        thx
                          UPDATE - Minix Neo X7 - wasser firmware 1.0.4 - KitKat Android 4.4.2
                          wasser
                          Passthrough does work in gotham SPMC with the 1.04 wasser rom. Also in the next version of SPMC the stagefright (hardwareacceleration) for the rockchip VPU will be fixed. (I have tested this new SPMC version and it will be released by Koying shortly).
                            Hello Guys
                            witch CFW would you recommend wassers 1.0.4 or quickshot v3.1, i am currently running QS v3.1 with some bugs that are not solved yet.
                              Pass through using spmc only produces static on my setup but works on wasser xbmc with the same setup. Maybe I should try it again to see if I can get it to work
                                Hi Freaktab community. I'm after some advice....
                                Obviously at this time I'm using wasser's ROM and XBMC included with the firmware. My problem is with XBMC, I get sound lag on everything I try and stream (within 10 minutes of starting the stream) to the point where I have to stop the feed. At this point I'll add I've tried other custom and official XBMC builds but the issue still exists
                                I have a very basic setup (x7 direct to tv via hdmi) and I've had a play with the settings on both android and XBMC but I can't resolve the massive lag?
                                So, any advice or setting recommendations will be greatly received. I open to try anything to keep this ROM on my x7.
                                Thanks guys!
                                PS. Many thanks to wasser for this ROM. It's the best kk build I've used on the x7. MINIX should take note of how a good 4.4.2 build should work, silky smooth and super fast!
                                Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
                                Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
