Originally posted by dodongdodong View PostSorry for the noob question. How do I make xbmc launch by default after boot up?
Not sure if it works with Wasser's rom
Originally posted by unlo View PostI searched the thread but I don't believe the results... Can this be safely installed via TWRP or is the batchtool recommended for serious reasons?
Sent from MINIX X7
Guest
Originally posted by astral69 View PostThat will happen automatically when you install mxplayer,
you can also check the tiny box at the bottom to make it the default.
Mx must be a choice for streams or eg 1080 5.1 filenames together with the usual xbmc internal player
Why? Because too many movies goes dead after 10 min and noone seems to have another solution
My playercorefactory doesnt work with dvdplayer as default and mx pro as alternative
Plz help anyone
Plz help anyone
This is horrible to read and even harded to understand
Originally posted by Kiralina View Post1.Download terminal emulator from google play.
2.Rename the kernel you have chosen from the kernel pack kernel.img
3.Copy kernel.img to the root of internal sdcard (use included ES Explorer)
4.Open terminal emulator and use this commands:
su
flash_image kernel /sdcard/kernel.img
Be aware, there is a space between kernel and /. Don't miss it !
wasser for minix x8?
Hi!
Just wanted to say that this firmware is for me the most reliable and fastest I have aver tested. THANKS for this work!
I was just wondering if you are planning to make the same one for the minix X8, I have ordered one and must say that the current roms are not close at all to yours.
Please let me know if I can do something to help you developing that part.
Again ...Thanks
P
There are currently 2201 users online. 0 members and 2201 guests.
