    DTS and DD support
    Hello,
    This is a very big thread so I might have missed the answer to my question. If so - I'm deeply apologize.
    Does this ROM support DTS and Dolby Digital? I am having some problems with my current ROM.
    Also, Does this ROM supports HD netflix?
    Regards,
    Id
      Add this in new release:
      Sound settings stay remembered after reboot. Thx.
      I am back on stock 10b. I will wait for new release.
        need advise..
        does any one here got a problem with stock remote after updated to oc.kernel for v0.95? it was okey before update to oc.kernel, and bluetooth can't found any device while im tring to pair moga pro and note 3. any advise? thanks
        Edited: after reboot my note3 found on bluetooth but moga pro still not recognize on bluetooth.
          Originally posted by ilovemymac View Post
          How do you flash the overclock kernels?
          Sent from my iPhone 5 using Tapatalk
          I used tincore quickflasher. Follow direction in play store app description.
            It works for me! can someone reproduce this issue?
            wasser
              it's very easy, just install terminal app, copy the oc kernel to /sdcard and then
              type the folling command in the termimal:
              flash_image kernel /sdcard/kernel.img
              reboot
              it's all!
              wasser
                reboot
                it's all!
                wasser
                Hi Wasser and all user,
                I install Android Terminal Emulator, and copy the kernel i wanted , renamed as kernel.img and put it under /sdcard (mnt/sdcard) directory, i type "flash_image kernel/sdcard/kernel.img" and it reply"usage: flash_image parition file.img"
                Am i success to flash the kernel?
                Seek for help
                  I press "Down" to auto hide the toolbar for full screen function, but how can i restore the toolbar back from full screen ? Sorry to interrupt.
                  Tks
                    KitKat-4.4.2 for Minix X7
                    Can you use tincore quick flasher to do it?
                      Seek for help
                      it should be:
                      please pay attention, it's a blank between kernel and /sdcard/kernel.img
                      wasser
                        IR remote not working with ok-kernel
                        I can confirm that IR Remote not work with ok-kernel. With original kernel IR Remote is okay.
                          Does the A2 remote work? What about the mic from the remote?
                            i can reproduce this issue too, will fix it and upload new oc kernels again.
                            thanks for testing!
                            wasser
                              both should work
                              wasser
                                Tks
                                Swipe down from the top of the screen or swipe up from the bottom of the screen.
