wasser
KitKat-4.4.2 for Minix X7
We can check the source
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
I'm working on lockscreen issue, it will be availble in next firmware release too.
wasser
The audio is out of sync in Netflix. UK and US streams. Slightly delayed.
If the parameter is increased in the next release it would be great. currently only 1gb is allocated for apps.
I don't see why the entire memory isn't useable on custom roms, like on the Nexus 10 tablet. Does it cause any issues in the operating of the unit if it is?
Otherwise this rom is working really great. Videos are really smooth. I was having a problem with a particular streaming app that wasn't working well on the JB roms, working great on this. The entire system is so fast. Ktkat is awesome.
Thank you very much for all the effort.
Forgot to mention that the little blue light on the front keeps flashing as if the unit is in standy mode. No biggie as long as the important stuff is working well.
Passthru
wasser
anhil
Originally posted by anhil View PostI wonder whether you have noted the reported problems with passthrough and could we expect some developments on those issues - and maybe the libmedia.so hack to enable passthrough for XMBC in your next release...?
anhil
wasser
screen scale setting
Originally posted by wasser View Postthe bug in displayd is fixed. Now the screen scale setting does persist after the reboot. The fix will be included in next release.
wasser
Could you add this fix to 0.94 now. I can't to use 0.94 if screen scale setting does not persist after the reboot. And I don't know how long need to wait new release!!!
Thank you!!!
Originally posted by killain View PostCan't get it to work, keeps saying it can't extract the image file.
There are currently 2450 users online. 2 members and 2448 guests.
