Minix x7 mini
Hi
Sorry if this is a stupid question but will this work on my Minix x7 Mini?
Ian
Originally posted by wasser View Postversion 0.95
- update busybox
- update google apps
- add hardware keyboard
- restore screen scale setting works now
- add lock screen
- make Google Launcher3 as default Launcher
- remove nova launcher
- remove google searchbar
- add screen rotation
- enable tun in the kernel
- add notifacation sound
Link download: wasser-firmware-kikat-minix-x7-0.95.zip
please use RKBatchTool to flash the new firmware
version 0.94
- kikat 4.4.2
- usb webcam support
- sound device manager
- wifi support
- ethernet support
- bluetooth support
- ir-remote support
- init.d support
- rooted
- ntfs, nfs, iso, cifs filesystem support
- preinstall es file manager
- nova launcher
- cwm recovery
- added 1080p24hz, 1080p30hz
Link download: wasser-firmware-kikat-minix-x7-0.94.zip
version 0.92
- Ugoos Ut1, k-r42, t-r42 and minix x7 (please select the correct kernel)
- kikat 4.4.2
- wifi support
- ethernet support
- init.d support
- rooted
- preinstall es file manager, reboot
- cwm recovery
- added 1080p24hz, 1366x768p60hz support
Link download: firmware-wasser-0.92-4.4.2.zip
parameter files (thanks to 900supersport)
new kernels fix ethernet, wifi, bluetooth, ir-remote issue:
kernel-neox7-720p.zip
kernel-neox7-1080p.zip
oc kernels:
CPU: 1008/1200/1416/1608/1800, DDR: 720, GPU: 400/600
kernel-minix-x7-160114.zip
CPU: 312/504/816/1008/1200/1416/1608, DDR:720, GPU: 133/200/266/300/400/600
kernel-1080p-ddr720.zip
CPU: 1008/1200/1416/1608/1704/1800, DDR:720, GPU: 133/200/266/300/400/600, 1080P
kernel-ddr720-cpu1800h-1080p
CPU: 1008/1200/1416/1608/1704/1800, DDR:720, GPU: 133/200/266/300/400/600, 720P
kernel-ddr720-cpu1800h-720p
cpu1704h/cpu1800h gpu798h ddr800 1080P, cpu1704h/cpu1800h gpu798h ddr720 1080P
cpu1704h/cpu1800h gpu600h ddr720 1080P, cpu1704h/cpu1800h gpu600h ddr800 1080P
oc-kernels-1.zip
Be aware: it is your own risk!
Originally posted by lewys View PostI installed Airpin from link provided by arhim, it works, but after 5-6 minutes of airplay it says that the app is unautorized.
Originally posted by Lachty View PostI install version 0.95 today (I must change usb cabel for boot to flash mode).
Bugs:
2.Minix Air A2 mouse button home, switch window and options button I can not use with this rom.
Wasser, please add it to new release too!Attached Files
Originally posted by Cantenna View PostAwesome! Thank you Wasser. Gio965 updated comix cursors as well, now im set
Cheers!
There are currently 1768 users online. 1 members and 1767 guests.
