Could you provide source code for us to research?
Originally posted by ididid View PostDoes this ROM support DTS and Dolby Digital?
Originally posted by Molle View Post
do you mean the default mali_init_clock ? if yes, it's not included in 0.95. I will add it in next 0.96.
the new feature "Auto hide systembar" will be included in 0.96 release too!
wasser
Originally posted by Molle View PostYes, passthrough works with e.g. MX Player.
It has been worrying me for some time that one time it works and another it does not
I believe I have pinned it down now.
For DTS passthru to work the HW and SW decoder functions must be unchecked
Originally posted by wasser View Postdo you mean the default mali_init_clock?
Code:insmod /system/lib/modules/mali.ko mali_dvfs=133,200,266,300,400,600,798 mali_init_clock=133
KitKat-4.4.2 for Minix X7
Just installed 0.95 on my box. Great Work dear Wasser.
For the first time in last 3 months, I am able to play 1080p/3D movies from my NAS without buffering using WiFi.
Still I believe the LAN needs to be optimized as LAN gives lower speed rates than the WiFi or is it me only....?
Originally posted by Kajukenbo View PostCould someone please tell me which page changing parameter files with rkbatchtool is on?
Thank you I couldn't find it.
Originally posted by Hjhoekie View PostHi, until now I use quickshot v2,can anyone tell wy I should use this one (kitkat)? Is it better, or should I stay with quickshot?
I agree this rom is by far the best one for Minix X7.
Wasser has done a great job.
Originally posted by Cantenna View PostIt's been a while since I tested others developer build but when I last tried them all I found this rom to have the least random hangs, crashes and occasional reboots. For me it was the most stable.
There are currently 1917 users online. 4 members and 1913 guests.
