Sent from Galaxy Note 3 via Tapatalk.
Originally posted by wasser View PostHi karel, thanks for the xbmc build . could you or someone please test if it works fine with patched libmedia.so.
If it works i will add it in 0.96 release which i plan to release at this weekend.
Some highlights of next coming 0.96 release:
- perfect fullhd video streaming
- auto hide systembar
thanks,
wasser
When can we to try new 0.96 release?
Thanks for your great job!!!
Originally posted by ajamils View PostJust flashed the ROM and so far it works better than all other ROMS that I have tried. Video playback is smooth. The only few issues that I've come across so far are following
1) Sound output selection resets after restart.
2) Not all buttons work on A2. Three main buttons Home, Options and Recent Apps don't do anything. Is there any fix for this ?
3) Wifi Display does not work. Tried it with Note 3 and Surface Pro 2. It tries to connect but fails.
Request:
- Add option for restart in power menu.
- Hide task bar by default.
2. It will be fixed in next firmware release.
3. WiFi display is closed source, only Rockip can fix it. sorry
wasser
Originally posted by lewys View Postwasser,
kernels for 0.95 are 1080p or 720p?
wasser
Re: KitKat-4.4.2 for Minix X7
Originally posted by wasser View Post1. it's correct behavour when usb sound device is added and detected. In your case A2
wasser
- usb camera issue with dark image.
- add reboot and reboot in bootloader mode
wasser
Originally posted by wasser View Postplease be patient, There're still 2 issues (see below) which i want to fix for 0.96 release.
wasser
Will we be able to flash the upgrade without wiping 0.95 version? I would really like to keep everything as is because it took me sometime to set it up to wife's liking
Originally posted by danfozzy View PostWasser Any chance you can look at the libmedia.so again, can't get passthrough with this Rom, but can with others
leolas
sent from my phone.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Passthrough patch for the official XBMC Gotham release...?
@karel : Have you already patched the official XBMC Gotham release in addition to RC1? If so could I kindly request a copy...
Did stafsrom ever release a patched libmedia.so for KitKat not having the known issues with Skype and similar apps?
anhil
There are currently 3126 users online. 0 members and 3126 guests.
