Originally posted by arhim View Postthanks
Please let me know if it fix the crashes
thanks
Originally posted by wasser View PostArhim, could you please try this new kernel, i even uploaded it.
thanks
- usb webcam hd 920 logitech make color stripes
- now i am watching youtube full hd
freaze and crashed on yotube
But I'm retarded and a newb so how do we flash just the kernel with RKBatchTool? in meantime I'll search...Last edited by markwerline; 16 May 2014, 02:45.
Originally posted by wasser View Post1. it's needed for multiuser support.
- internal_sd be disabled altogether
- the full 16GB be allocated to internal storage
It seems to me that otherwise the device is, in effect, reduced to a 6GB model.
Originally posted by arhim View PostVersion 1.0.1
crashed when i copied files from usb flash drive
crashed when i reconnected usb webcam
crashed when i turned on wifi first time with ethernet on
crashed when i used skype first time
crashed when i installed many apk files from internal sdcard
many random crashes
Webcam Logitech c920 hd work EXELLENT with skype
Sound settings saved after reboot
Thanks !!!
I can confirm random shutdowns with 1.0.1 release.
Other bugs:
Sometime red frame appear in chrome, I guess that frame comes from non standart (?) scale settings page. Also my airmouse is detected as physical keyboard and I have to disable it after every reboot. But the release is just great! If wasser will fix these bugs it will be perfect firmware.
Originally posted by Molle View PostOk, but shouldn't then- internal_sd be disabled altogether
Originally posted by markwerline View PostAnd now I can't flash back to 0.95 as my minix wont stay on long enough to stay connected and flash! has anyone ever run into this? Im lost will be picking this back up tomorrow hoping i didn't brick it.
Originally posted by lewys View PostI can confirm random shutdowns with 1.0.1 release.
Other bugs:
2. i already saw this reports about red frame, could you please give the link so i can see this issue.
thanks
Originally posted by wasser View Post1. the problem is that i cannot reproduce the random shutdown. I need a simple testcase to reproduce this issue. Could you please try to flash the kernel from 0.95 and see if the random crash is gone?
thanks
thanks
1. I will try to flash the kernel later, but I used 0.95 before I flashed 1.0.1 and it was very stable.
2. I cannot give the link because it just sometimes appears for 0.5s (I saw it only in Chrome) and the frame looks just same as in screen scale settings.
What about Airmouse issue? It is very annoying to disable physical keyboard after every reboot. Is there some way to fix it?
Thanks in advance!
P.S. Just now MiniX crashed, I haven't touched anything, it was just on desktop without any activity.
Originally posted by lewys View Post1. I will try to flash the kernel later, but I used 0.95 before I flashed 1.0.1 and it was very stable.
Thanks in advance!
what is exactly problem with physical keyboard? could you please post more infos?
thanks
There are currently 5358 users online. 2 members and 5356 guests.
