EDIT: Here is the link to HDMI Virtual Switch where I got the idea from:
Guest
Originally posted by wasser View Postas i know strick mode is disabled by default in 0.92. COuld you please check it in Settings->Development->Strict mode
Originally posted by Molle View PostAnother discovery. CWM recovery is unable to mount the external_sd when I try to use it for backing up the system.
could you please attach the output of "ls -l /dev/block/" ?
thanks
Originally posted by soyrme View Post"Supposedly" this should still output to HDMI. I will test state 0 and save everyone the aggravation, and reflash to standard "1" state if "0" state doesn't output anymore to screen. However, i haven't found a way to change the 1 to 0 in state file and have it save, even though rooted. Any idea how to save this to 0? There is an app called HDMI State something or other in freak tab that does this and works for other tv boxes and apparently they can play hdmi blocked apps and still output to screen even though set to state 0, but it doesn't work for the X7.
http://www.freaktab.com/showthread.p...t=hdmi+state+0
i uploaded new kernel which now hides the hdmi state. Could you please test if it works for you and if there's any regression in hdmi.
Guest
Originally posted by wasser View Postcould you please check if the /dev/block/mmcblk0p1 exists?
thanks
Would my information be usefull aswell?
Also, any clue why there is no audio manager in kitkat? I've tried looking it up on Google but I see it nowhere that people are missing it out of their rom.
Did RockChip remove it for some reason? And if so, would the files from the 4.2.2 rom work?
Originally posted by DeliriumNL View PostI had this when i regressed back to 4.2.2 (HFW 3.2 from Lewy20041), it seems to still not be mounting !
2. no, 4.4.2 sdk is for tablet and doesn't have audio manager. It's still needed to add
Code:brw------- root root 254, 0 2014-01-24 22:52 dm-0 brw------- root root 7, 0 2014-01-24 22:51 loop0 brw------- root root 7, 1 2014-01-24 22:51 loop1 brw------- root root 7, 2 2014-01-24 22:51 loop2 brw------- root root 7, 3 2014-01-24 22:51 loop3 brw------- root root 7, 4 2014-01-24 22:51 loop4 brw------- root root 7, 5 2014-01-24 22:51 loop5 brw------- root root 7, 6 2014-01-24 22:51 loop6 brw------- root root 7, 7 2014-01-24 22:51 loop7 brw------- root root 179, 0 2014-01-24 22:51 mmcblk0 brw------- root root 179, 1 2014-01-24 22:51 mmcblk0p1 drwxr-xr-x root root 2014-01-24 22:51 mtd brw------- root root 31, 0 2014-01-24 22:51 mtdblock0 brw------- root root 31, 1 2014-01-24 22:51 mtdblock1 brw------- root root 31, 10 2014-01-24 22:51 mtdblock10 brw------- root root 31, 2 2014-01-24 22:51 mtdblock2 brw------- root root 31, 3 2014-01-24 22:51 mtdblock3 brw------- root root 31, 4 2014-01-24 22:51 mtdblock4 brw------- root root 31, 5 2014-01-24 22:51 mtdblock5 brw------- root root 31, 6 2014-01-24 22:51 mtdblock6 brw------- root root 31, 7 2014-01-24 22:51 mtdblock7 brw------- root root 31, 8 2014-01-24 22:51 mtdblock8 brw------- root root 31, 9 2014-01-24 22:51 mtdblock9 drwxr-xr-x root root 2014-01-24 22:51 platform brw------- root root 8, 0 2014-01-24 22:51 sda brw------- root root 8, 1 2014-01-24 22:51 sda1 drwx------ root root 2014-01-24 22:51 vold brw------- root root 253, 0 2014-01-24 22:51 zram0
Guest
Originally posted by wasser View Posti uploaded new kernel which now hides the hdmi state. Could you please test if it works for you and if there's any regression in hdmi.
Thanks again for trying!
Try this APP which has worked for some on hiding HDMI to apps.
Hi.
Thanks a lot for this ROM, there are a number of features in 4.4.2 that I want to use on my X7. One major issue I am having is that I am unable to get it to present itself to my computer over adb.
On other ROM's this is done through an option that they have added into the android settings.
I am not too clued up on how that works behind the scenes and thus can't implement it myself. Do you have any idea (or know how to find out) what needs to be done to either create this option or have this enable by default?
Thanks.
awesome!
i tried v .92 with stock kernel and had issues that was mentioned before like white bars during boot and restarts/shutdowns. with oc kernel (kernel-minix-x7-160114), everything is really smooth and fast. excellent work wasser and everyone who worked on this rom.
one thing i noticed rightaway is that my IR remote is not working, eventhough it says ir-remote issue is fixed in this kernel. I used stock remote (minix x7 remote) as well as my harmony remote but none of the command works. is there any fix for making ir remote accept commands?
again, awesome work!
Guest
Originally posted by Finless View PostTry this APP which has worked for some on hiding HDMI to apps.
Thanks.
Originally posted by ceace1314 View PostYeh i have came across this issue myself. Pretty sure is was a section for USB in the settings menu that enabled it in the other roms i have run in the past.To Infinity and Beyond.... XBMC
There are currently 2633 users online. 1 members and 2632 guests.
