Sent from my GT-I9505 using Tapatalk
Re: KitKat-4.4.2 for Minix X7
Test spdif
Originally posted by wasser View PostHi all,
i have tried to to build new kernel with spdif support. Could someone please test if spdif works?
thanks
http://www.freak-tab.de/wasser/kerne...x-x7-spdif.zipOriginally posted by aggro600 View Postwill spdif be fix in the new release?
Did you test the kernel with spdif? If yes, how did it work out?
Originally posted by wasser View Postplease take a look at earlier post you will find other parameter files!
A lot of ppl are asking about files of all kinds, and since this thread has a lot of posts now, it's troublesome to find the exact one you want, or the newest. It leads to a lot of uestions-= HELLO KITKAT =-
ive tried finless and the hardwareguru roms and this rom is the most stable for me. It's also the ONLY rom that lets Google Play Music All access work properly (I pay a monthly fee for this, i want it to work!). I do have one suggestion, can you add a second setting that controls mouse acceleration seperately? My touchpad mouse goes a little crazy when mouse speed is set to high, but requires too much movement when set to low. Thanks!
Originally posted by Smokez View Postmolle stated that my CPU probably isn't taking too well to it. I had the same problem with finless ROMs and kernels
Originally posted by Molle View PostOne idea springs to mind. Try a different PSU. I'm using a 4000mA one.
Originally posted by Smokez View PostDidn't think of that. Might have to give that a go if I can get hold of one cheap enough. Bit concerned when over amping certain things but if you've tried and tested without problems I will give it a go. Thanks again
Sent from my GT-I9505 using Tapatalk-= HELLO KITKAT =-
Originally posted by flemming View PostEquipment will not be harmed by ampere as such. It's the voltage that you need to look out for.
Now... Wasser any chance of a 720p kernel oc'd to 1704 or at least adding the 1704 step to the current one, if not does anyone know of a work around for this, I would love to be able to run this ROM at near full potential while I try to acquire a 4amp power supply to see if that solves my issues with antutu force closing, as I am more and more suspecting this could be the problems as I've had a couple of reboots this evening with CPU set at 1800
how to apply new kernel for wifi fix
Originally posted by wasser View Postversion 0.92
- Ugoos Ut1, k-r42, t-r42 and MinixX7 (all revision support, please select the correct kernel)
- Kikat 4.4.2
- wifi support
- ethernet support
- init.d support
- rooted
- ntfs, nfs, iso, cifs filesystem support
- preinstall es file manager, reboot
- cwm recovery
- added 1080p24hz, 1366x768p60hz support
Be aware: it is your own risk!
Link download:
new kernels fix ethernet, wifi, bluetooth, ir-remote issue:
http://www.freak-tab.de/wasser/kernel-neox7-720p.zip
http://www.freak-tab.de/wasser/kernel-neox7-1080p.zip
oc kernels:
CPU: 1008/1200/1416/1608/1800, DDR: 720, GPU: 400/600
http://www.freak-tab.de/wasser/kernel-minix-x7-160114.zip
CPU: 312/504/816/1008/1200/1416/1608, DDR:720, GPU: 133/200/266/300/400/600
http://www.freak-tab.de/wasser/kerne...80p-ddr720.zip
Please can someone tell me how to install the kernel with WiFi and Ethernet fix?
Guest
Originally posted by wasser View Postit would be great if someone could test if spdif works!
thanks
It works and outputs through optical. some observations:
- There was a substantial lipsync issue when using hbo. The sound was almost 1 second faster than the video. Are you able to put a +/- lipsync option in to set it in 5 or 10 msec increments?
- There was no option to select hdmi, passthrough, spdif, etc output like in stock 006-009. If the cable is plugged in, the audo goes out that way, period. Are you able to add the standard stock options for sound output or is that a kitkat thing?
Let me know if you need to test something further on this.
Guest
Also tested 1080p/24 vs. 1080/60 output on another monitor for the hbo go video stuttering issue.
Using 24hz there is no stutter with hbo video but using 60hz or 50hz there is bad stuttering. Any idea how to fix that as the box I will be using this on doesn't have 24 hz only 60hz. There was the same issue on Showtime app.
Thanks in advance.
thanks
http://www.freak-tab.de/wasser/kerne...x-x7-spdif.zipThanks.
thanks
There are currently 2775 users online. 1 members and 2774 guests.
