Can anybody hint me how to disable any sort of gesture, or keyboard/touchpad/mouse gestures? it is making my X7 useless.
Originally posted by wasser View Post
i even uploaded new oc kernels,
cpu1704h/cpu1800h gpu798h ddr800 1080P
cpu1704h/cpu1800h gpu798h ddr720 1080P
cpu1704h/cpu1800h gpu600h ddr720 1080P
cpu1704h/cpu1800h gpu600h ddr800 1080P
oc-kernels-1.zip
have fun!
I am up and running with cpu1704h gpu600h ddr720 1080P
and so far seems very stable
1080 video comes though in tact, and so does 720
no upscaling? Not a problem as my amp will do that
Just looking for hdmi/spdif passthru so that I can watch DD and DTS
and Multiple USB for convenience.
Speedy Gonzales
Originally posted by wasser View PostHi Smokez,
i even uploaded new oc kernels.
CPU: 1008/1200/1416/1608/1704/1800, DDR:720, GPU: 133/200/266/300/400/600, 1080P
kernel-ddr720-cpu1800h-1080p
CPU: 1008/1200/1416/1608/1704/1800, DDR:720, GPU: 133/200/266/300/400/600, 720P
kernel-ddr720-cpu1800h-720p
Have fun!
wasser
Originally posted by Phycopat View PostSomehow it Sounds good, but in the end i dont get it.. Why that feature?
The Dutch public Television/Radio ( www.npo.nl ) use it for all their live streams, as well as the visual radio streams ( e.g. www.3fm.nl - camera icon ). And the commercial network "RTL" also uses it for it's "RTL XL" app.
When connecting to a live stream, an "m3u8" manifest is downloaded, in which several options for resolutions and bitrates are available. The player chooses the best attainable stream quality based on bandwidth and cpu.
The confusing part: Android 4.4 is not the only version on which it can be supported. The "3fm" app or their mobile website can already use adaptive streaming perfectly on even older Android devices I have owend. But I guess, with kitkat, this can be done more easily whereas, previously, apps would have to implement this themselves.
Lack of adaptive streaming (also refered to as HLS/Smoothstreaming) is a real pain in the ass on almost any ROM available for any Rockchip device. The Android SDK Rockchip has supplied prevents me from using any method to obtain those streams (www.3fm.nl visual radio hangs after 20 seconds, as soon as the player wants to switch to a higher resolution).
The only ROM on which I have seen this working successfully is the Strauzo SDK2 ( 4.2 ) ROM.
A few more observations after a night of viewing/testing
A2 Mouse keys not functioning
Tabs
Options
Main Menu
Volume is either on or off, no steps in between
(Well the steps are there, but not working)
Using MX Player Pro test build
Airplane mode icon showing?
Presumably because there is no sim, but there wouldn't be
The option also shows in the Power off menu.
Keep up the good work Wasser
Originally posted by pesky_89 View PostIs there a way to make stock browser flash compatible?
- Install Dolphin browser (and enable Flash support)
- Install this hacked version of Flash
Originally posted by dxben View Postkernel-ddr720-cpu180-720p
Unfortunately this is no .zip fie but .img
oc-kernels-1.zip
have fun!
cpu1704h/cpu1800h gpu798h ddr800 1080P - wont boot
cpu1704h/cpu1800h gpu798h ddr720 1080P - wont boot
cpu1704h/cpu1800h gpu600h ddr720 1080P - boots, systemui crashes a lot
cpu1704h/cpu1800h gpu600h ddr800 1080P - wont boot
i have to be very conservative with OC-ing in my box as it seems.
There are currently 2704 users online. 0 members and 2704 guests.
