If you choose to try the app, open it and choose app manager at bottom right of main screen then select Move at top far right tab. It should then list all and only the apps that can be moved, you can then select all of them at once and choose move.
Note: if you still have no option to move the app, this may be due to a specific limitation or problem with the ROM although I do believe Wasser's ROM doesnt have any issues moving supported apps that can be moved. Some apps unfortunately cannot be moved so checked other apps first to ensure this isnt a problem with the rom itself.
