Robert Lemke | Cologne (Ger)
Originally posted by robertlemke4 View PostWas the firmware also 'Wasser' before? If not you are gone a wrong way. 'Restore' button to flash the Minix X7 from another to Wasser.
So, from where I am now with no boot but still seen by RK batch tool 1.7 and 2.1 - What should I do next.
Put finless back (using rk tool 2.1) and start over with rk tool v1.70?
Note - I'm trying to flash it to Tronsmart T428 not an x7 just to keep things clear....
EDIT Back on Finless 2.0!
Now, someone please tell me how to get wasser 1.04 on it, please.
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
Originally posted by robertlemke4 View PostIf an error is showing like the one of your image, use rk tool 2.1 for restore finless 2.0 first and than rk tool 1.7 with wasser 1.04
EDIT: Got Wasser installed!
The only ~problem I'm having is that now the T428 isn't seeing my Tronsmart USB Ethernet dongle. So, no wired connection but the wifi is working. Anyone know if there is something I can change to get it to find the USB Ethernet dongle? Maybe a different one with a different chipset or an edit to some system file??Last edited by flhthemi; 11 December 2014, 14:29.FLHT = Harley
Originally posted by robertlemke4 View PostTry to setup in Android Settings > Developer (activate first on bottom) > USB Debugging and plugin the dongle again.
Too bad, the T428 is great on this ROM execpt for this problem.FLHT = Harley
Go to http://www.FreakTab.com/showthread.php?p=130286 and ask the developer in a private message.
Originally posted by robertlemke4 View PostGo to http://www.FreakTab.com/showthread.php?p=130286 and ask the developer in a private message.
I'm wondering if a different dongle, with a different chipset would work....is anyone else using this ROM on a T428 using a dongle for Ethernet having success?
Thanks for all you help, really I do appreciate it!Last edited by flhthemi; 12 December 2014, 15:30.FLHT = Harley
Originally posted by Martinlwd View Posthas this something to do with the brightness?
Install screen adjuster free and put contrast to 40
..i had the same problem and two pages back someone gave me this tip
Quickshot v.3.1 which i replaced with Wasser, did not have this problem, if not with some OC kernel...
Originally posted by vnishimoto View PostI'm using a dongle ethernet with T428 flawless. The T428 bored in geekbuying with dongle for free.
OK! Thank you for the reply!
@vnishimoto are you also using THIS Wasser 1.04 ROM on the T428?
This is the same USB dongle I'm trying to use. I have 2 of them and both work on the PC so I know they're good. I was using one on the Finless 2.0 ROM and it worked fine. After flashing Wasser 1.04 no luck at all. So maybe I should start over as I did have problems when I flashed it.
So now the n00b question - how do I erase EVERYTHING on the T428 (so I know nothing is there from the botched up flash) and then flash the wasser ROM...
I have both RKbatch tools V1.7 and 2.1....anyone....????Last edited by flhthemi; 14 December 2014, 20:17.FLHT = Harley
There are currently 2822 users online. 1 members and 2821 guests.
