Robert Lemke | Cologne (Ger)
UPDATE - Minix Neo X7 - wasser firmware 1.0.4 - KitKat Android 4.4.2
Originally posted by Stainy View PostInactivity?? It's literally two seconds.
Sent from my iPad using Tapatalk HD
increase in LAN performance possible?
Dear all,
first of all many thanks to all forum members; with your help my X7 became an almost perfect box!
I use it mainly for Kodi, with the target to reach a high WAF.
With Wasser's 1.0.4 ROM and SPMC based on Kodi 14.1 almost everything runs quite well & stable, with smooth video playback, live TV from a Mediaportal server etc.
There's only one thing I'm not so happy with: the ethernet performance.
I did not yet find any reliable figures about the maximum LAN performance of the X7, personally I get approx. 2 MB/s wired, which is quite similar to what I can get over WLAN.
It is more or less OK for German HDTV and SD movies, but for 1080p HD mkv content from a SMB share (WHS) it is not enough.
Therefore, any buffering tweaks in the advancedsettings.xml are not effective.
I tried some other ROMs in the past months, e.g. with the most current CE 2.2.0 I could get near to 4 MB/s via LAN, which is better but still not what I would like to have.
My (2) question(s):
Is it possible to speed up the LAN performance remarkably?
As there is a difference in LAN performance between the available ROMs, there should be an influence somewhere in the code.
Alternatively, could an USB to LAN adapter be an option?
I already tried 2 different ones (USB3 to 1000 and USB2 to 100) but with no success.
It is simply not possible to access or somehow configure them.
I guess the use of those things need to be foreseen in the ROM upfront?
So if anyone could give me a hint what could be done, I would be happy.
Maybe I'm not the only one with interest in higher LAN performance.
I will for sure survive without having a solution for this, but improving this point could extend the device's lifetime remarkably.
Many thanks in advance,
10fighter
CIFS NFS script for init.d
SuperSU is required!
CIFS
Code:#!/system/bin/sh insmod /system/lib/modules/nls_utf8.ko insmod /system/lib/modules/md4.ko MOUNTS="SAMBA" busybox sleep 20 if [ ! -d /data/media/0/${MOUNTS} ] ; then mkdir /data/media/0/${MOUNTS} fi busybox sleep 40 su --mount-master -c busybox mount -o username=anonymous,iocharset=utf8,file_mode=0777,dir_mode=0777 -t cifs //192.168.1.2/smb /data/media/0/${MOUNTS}
NFS
Code:#!/system/bin/sh MOUNTS="STORE" busybox sleep 30 if [ ! -d /data/media/0/${MOUNTS} ] ; then mkdir /data/media/0/${MOUNTS} fi busybox sleep 30 su --mount-master -c busybox mount -o rw,,nolock,intr,hard,vers=3 -t nfs 192.168.1.2:/store/smb /data/media/0/${MOUNTS}
Originally posted by astral69 View PostI am running Wasser 1.0.4 on my Minix X7, playing files from a usb hard disk using the latest Kodi
I get random pauses, with the player going into pause mode, no action in my part.
I have to press the play button to resume
Mildly irritating
Any ideas?
Move the drive to a network computer and share it then use it from Kodi and see what gives. I'm thinking USB port may have issues and doing this would eliminate that?FLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
I found quite early on that my 2.5" 1TB USB-only HDD requires more current than the X7 is able to provide through the USB ports. After connecting the HDD through a powered USB hub with a 2A high-current port all dropouts etc. vanished.
There are currently 2665 users online. 1 members and 2664 guests.
