Originally posted by givecredit View Post
Just to update re google music. Installed Wasser 202 rom together with patch. Google Music works perfectly on it. This is first time I have got Google Music to work on any Android tv device.
Originally posted by midelpo View Post
I can help you if you want. In official firmware 230 they have created this patch: HDMI flicker patch: http://www.minixforum.com/downloads/...ickerPatch.zip
i uploaded new kernel which should fix the HDMI flicker. Please test it and give me the feedback!
Originally posted by jaksa72 View PostI am unable to download latest firmware 2.03
SSL conection error
thanks for quick replay. i will be more patient.
Please report the feedbacks, it's very important for me to improve the firmware!
Enjoy
Wasser
Originally posted by himmon View PostBrilliant ROM Wasser!!, so glad you came back. Was just about ready to dump my x7 on **** as just couldnt find a 4.4.2 rom that would work properly with HULU, VEVO & Xfinity TV Go. I bought a $25 mk808b plus just to get hulu to work as noboby could get it working on 4.4.2 for the x7 now that you've cracked it, brilliant!
I used HG's 4.4.2 CE roms for ages up to v2.30 but gave up as still no working solution / support for HULU and other HLS streaming issues I've found.
Your rom however, brilliant. Extremely clean and fast with OC options too. Every single streaming app I've thrown at it works perfectly now, netflix, hulu, vevo, Xfinity, vimeo, vidzone, showbox, Kodi, Amazon Instant video, and many other UK streaming apps.
Two minor issue/requests if possible, sound output options dont save on reboot and also if its possible to remove the VPN PIN request as I use VPN for USA based streaming apps which forces you to set a pin. Official minix 4.4.2 roms have removed the pin request to configure a VPN account.
Thank you again. I'm extremely grateful for your work with this and for anyone else having issues with Hulu plus, do give this rom a try, it's great! Cheers!
Thanks,
Wasser
Originally posted by jaksa72 View Posthi .Thanks for great firmware . I dont know if it is a bug but sound INPUT preference is not saved after reboot with sage airmouse.
Firmware wasser 2.03
Wasser
Originally posted by wasser View PostHi all,
Wasser Firmware 2.0.3 for Minix X7 is released. For more infos please take a look at the first post!
Enjoy!
Wasser
Hi, sorry for the noob question but, how do you update from 2.0.2? I don't want to start from scratch
Originally posted by wasser View Postit seems nobody is interested in testing HDMI flicker fix. What a pity!
Wasser
Enjoy!
Wasser
Can you consider, please to add to the firmware, if It is feasible, that the "Screen Scale" options to adjust/fit the screen can handle the four sides independently from each other, I mean, up & down separately (not as it is now combined vertical screen adjustement), same for horizontal screen adjustment, left and right separately?; exactly that it´s been done currently for the rk3288 (R-89 with your firmwares). In some TV´s models this way to fit to the 100% of the screen make the difference.
The Neo X7 with your rom had been reach a very mature point, exceeding in many situations the day to day performance of newer and poweful systems like A80 & rk3288; Minix owe a lot to you; you had shown to them the way to implement properly android 4.4.2 with all of the goodies and the single 16Gb partition on RK3188; if still they are selling Neo X7 it´s because of your good work had help them a lot. Thanks again for your wonderful work.
There are currently 2646 users online. 1 members and 2645 guests.
