Thank you!
hello guys i am on quickshot v2.0 and was thinking upgrading here but a few questions, so if anyone coul help i would be most aprreciated.
1- is there a place where i can see screenshots or a video of this rom?
2- is it relly worth it to upgrade from 4.2.2 to this?
3- does wifi display works fine? did anyone try with samsung phones?
thanks
Originally posted by Molle View PostAfter two days of testing I can honestly say that 2.0.2 is the best ROM I've used on my X7. With the oc'd kernel and my Mali-patched boot image all actions are quick and video playback is super-smooth.
Extra plusses:
+ The new sound devices manager is nice and clear
+ RKlibstagefright acceleration with SPMC-14.2 works out-of-the-box (video.use.overlay=1 pre-set in build.prop)
Some criticism:
- The new mouse cursor is a step back from the normal arrow
- USB disk mounting omits the partition from the path (i.e. '/mnt/usb_storage/USB_DISK0' instead of '/mnt/usb_storage/USB_DISK0/(1)')
Please post the feedbacks!
WasserLast edited by wasser; 21 April 2015, 21:43.
Originally posted by johnnyzazza View PostHello Wasser, can you please provide a flashable zip to return to stock kernel?
Wasser
Originally posted by mowgli View PostHi Wasser! Are you planning to release similar firmware for Minix x7 mini ? Please, say "Yes"
Wasser
The default recovery doesn't appear to support my wireless keyboard (Logitech K400r). Abdul's TWRP-2.8.5.0, however, works nicely. It can be found from here:
http://freaktab.com/forum/main-categ...048#post419048 (flashed the 'TWRP RK31 KitKat Landscape DATAMEDIA' version)
I tried to flash the mounts update through TWRP but although a) it flashed ok b) the file dates of the updated binaries and build.prop have changed, the partition bit is still missing from the path. This is, however, a very minor issue. I have already adjusted all relevant apps to ignore the partition.Last edited by Molle; 23 April 2015, 16:31.
There are currently 2639 users online. 1 members and 2638 guests.
