Originally posted by wasser View Post1. i will check otg issue and provide a fix soon.
wasser
I came from stock 010 FW directly to this wasser v1.0.3 rom and the experiencie it´s very pleasant except for having the usb-otg port turned off; the "connect to pc" option works ok, with the device auto-installing drivers on PC when connected as a "nexus 10".
Originally posted by astral69 View Post1.0.3 downloaded and installed today without any hitches
XMBC working perfectly, without the lipsync problem
as far as I can see
A total convert from MX Pro!!
I am not streaming, not enough bandwidth
only viewing from usb disks, stocked from torrents
Small donation sent
thanks
Originally posted by Pilson View PostHow to flash kernel?
RKBachTool says: Loading Firmware Failed....
1- install terminal app and launch it
1. copy the kernel.img file to /sdcard/
2. flash_image kernel /sdcard/kernel.img
wasser
Originally posted by BTR11 View PostThanks; I will appreciate a soon fix, because in my case losing the usb port # 1 in priority on X7 affect a lot my device usage; I had tried as well the OC 1704h & 720 ddr to see if this will solve the problem, but it´s not; however I stay with this 1704h OC kernel because the antutu raise up a little, the device is stable; I have not any single problem with ethernet nor wifi with v1.0.3; wasser xbmc 1.1 experience it´s the best so far for me, and even the basic streaming app CloudTV from minix stock it´s great over here. Only good words for this rom, webcam working good here as well.
download url: http://www.freak-tab.de/wasser/kerne...x-14062014.zip
thanks,
Originally posted by Decapper View PostHave hdmi and using patched xbmc and hacked libmedia.
All I get when playing ac3 5.1 is a lot of static...
Did I do something wrong?
Edit : wipes stupidity from face and realises oneself is truly stupid
please try 1.0.3 ;-)
Originally posted by wasser View Posti even uploaded new kernel which should fix the usb-otg port issue. Please test and let me know if it works for you!
thanks,
This kernel image from the link is smaller in size (10837 kb) than the original & oc kernel provided with 1.0.3 (10913 kb)?
Originally posted by Phycopat View PostWill try that laver today Yes, could it help you If you got a VPN and a login for Netflix / viaplay?
Wasser XMBC passthru 1.0.3
I am watching the new Star Trek movie with DTS sound track
but cannot persuade the passthru to work in XMBC.
The option is checked, and have tried SPDIF and Rock on the Sound Device Mgr
but no passthru.
Reverting to SPDIF and MX Pro, the amp immediately locks on to the DTS signal.
AW: UPDATE - Minix Neo X7 - wasser firmware - KitKat Android 4.4.2
Originally posted by astral69 View PostI am watching the new Star Trek movie with DTS sound track
but no passthru.
mx player standard works fine.
in xbmc not working.
Screenshots:
http://www.picfront.org/d/98Fp
http://www.picfront.org/d/98Fq
gesendet von meinem Minix Neo X7 Wasser Firmware v1.0.3Last edited by mrosys; 14 June 2014, 13:04.
but no passthru.
Settings->System->Audio ouput->Enable passthrough
To get the option (enable passthrough in xbmc) you have to set Setting level (Settings->system) to expert and set Outpur configuratiion to Best Match.
Please try again.
wasser
There are currently 3194 users online. 1 members and 3193 guests.
