gesendet von meinem Minix Neo X7 Wasser Firmware v1.0.3
Originally posted by wasser View Postdts passthrough is disable in wasser xbmc by default, you have to enable it in
Settings->System->Audio ouput->Enable passthrough
To get the option (enable passthrough in xbmc) you have to set Setting level (Settings->system) to expert and set Outpur configuratiion to Best Match.
wasser
Not quite as you described but in the XBMC System/Audio/Expert
could enable DTS receiver
AC3 was already enabled
Originally posted by BTR11 View PostTested but unfortunately did not fix the problem, usb-otg is still turned "off".
This kernel image from the link is smaller in size (10837 kb) than the original & oc kernel provided with 1.0.3 (10913 kb)?
download url: http://www.freak-tab.de/wasser/kerne...14062014-1.zip
thanks
wasser
Originally posted by wasser View Posti built new kernel which now fixes the usb-otg issue. Please test and give me feedbacks!
thanks
wasser
On this new kernel the usb-otg issue was solved, it´s Ok in this matter, but the webcam image quality had changed, it´s darker now and with some visual artifacts and screen blinking when the camera app is being used; not sure if there are some other changes on it. Honestly, I like the way how the original 1.0.3 kernels and OC kernels behave, it just will be great if usb-otg port can work properly without introduce more changes to the kernel, because the original ones are quite right except for that usb-otg issue, at least until the new version of you fw be released where you say that may be the one big single partition can be introduced. Thanks for your great support and work.
It's only small change and i don't think it could cause such problem.
Have you changed something on system? Can someone else reproduce this issue too?
I have updated the firmware 1.0.3 (filename is the same) yesterday, which fix usb-otg port issue and other critical issue (permission issue). Could you please download it and try again? please give me the feedbacks
thanks
wasser
Wasser, I've been using version 1.0.0 since its release but I moved to the latest one yesterday and though most of the things work fine the major issue I have is the full screen videos from website no longer work and I just get black screen with sound. I'm using Dolphin browser (with jetpack) and hacked Flash version 11.1. This same setup was working fine with the previous version of the rom.
Any suggestions?
Sent from my SM-G900T using Tapatalk
Originally posted by ajamils View PostWasser, I've been using version 1.0.0 since its release but I moved to the latest one yesterday and though most of the things work fine the major issue I have is the full screen videos from website no longer work and I just get black screen with sound. I'm using Dolphin browser (with jetpack) and hacked Flash version 11.1. This same setup was working fine with the previous version of the rom.
Any suggestions?
does it work with stock browser?
thanks
Re: UPDATE - Minix Neo X7 - wasser firmware - KitKat Android 4.4.2
Originally posted by wasser View Postcould you please give testcase to reproduce this problem?
thanks
You can also test it with couchtuner.eu website.
Originally posted by berrani View PostI am trying 1.0.2, very fast and stable (thanks wasser for the great work).
Can someone confirm me that with new 1.0.3 fw the autohide systembar function works like in 1.0.2? Or now is only manual?
wasser
Trying this rom and Quickshot today, after using justXBMC... justXBMC puts out 1080p @ 60hz just fine... Wasser and Quickshot 3.1 both do too, except there are lots of pixels that flicker. The whole screen stays, but pixels will appear white or green or some other color, all over the screen distorting it. Any ideas on how to fix?
There are currently 3777 users online. 0 members and 3777 guests.
