Gesendet von meinem Nexus 10 mit Tapatalk
Originally posted by berrani View PostThanks wasser, we can update the old apk or is better to proceed with a fresh install?
Originally posted by toeter80 View PostNobody using Play Music here? I can't get it to play multiple songs in a row; after one or two songs playback always stops. I can turn it on from the notification bar button, and all is fine, but one song later it will stop again. I dont't know where this bug originates; first I thought it had to do with the audio output device not sticking, but that's solved now so it must be something else.
it's on my todo ist.
Hi Wasser,
i have a problem with tvheadend with your ROM, i guess it has something to do with the permissions.
The Kernel Modules are loading fine, the DVB-T stick is recognized and successfully added.
But as soon as i start the tvheadend, i get an error:
Code:[COLOR=#333333][I]ERROR unable to open /dev/dvb/adapter0/frontend0[/I][/COLOR]
the path is correct though. maybe permissions?
did work fine with 4.2.2.....
any ideas?
Dennis
OC Kernel
Hello,
Sorry for the Noob question.
I just flashed the Wasser 1.0.3a yesterday and I can say, its way much faster than the stock 010 I was using and the wasser xbmc included is just awesome (it solved my known problems). I still have to try wasser xbmc v2.
I wanted to flash the OC kernel and I was wandering how to do that.
Can I use the method from this link?
Many thanks,
Vab
Many thanks,
VabOriginally posted by wasser View Post1- install terminal app and launch it
1. copy the kernel.img file to /sdcard/
2. flash_image kernel /sdcard/kernel.img
wasser
you can use terminal to Flash oc kernel
Originally posted by mrosys View Postyou can use terminal to Flash oc kernel
And how much overclocking do you suggest for a faster and still stable ROM? I mainly do xbmc, youtube, occasional gaming and hi-res movies (in xbmc with subs).
Thanks a lot,
Vab
Crazy screen flickering
Hi all,
just flashed the most recent 3.1a Rom onto my X7, but I'm having problems... I'm getting quite a lot of flicker, especially at the top of the screen, and when I enter the File Explorer, or any app with a white background, the screen goes crazy with flicker. Can anyone explain this?
Previously I was on Finless 1.6 Rom and flashed 3.1a directly "on top of" it... Should it have been done a different way?
Also, what use are the overclocked Kernals? Are the simply to add speed? If so, I don't need to experiment with them just yet, but if there are other practical reasons to give them a try, please let me know.
Thanks.
Originally posted by vab.android View PostThank you for the quick response. Does it mean I also have to rename my desired kernel as kernel.img?
Thanks a lot,[ATTACH=CONFIG]6766[/ATTACH]
Vab
I got this error. I'll appreciate if somebody can help me flash the OC kernel. The file got attached in the quote by mistake.
Thanks,
Vab
Originally posted by vab.android View PostI tried flashing the kernel with three different terminal applications.
Thanks,
Vab
su
I tried the XMBC v1.2 with the old 1.0.3 kernal
firstly overwriting the old XMBC ,then as a clean install
Same error in both cases, it just hangs on the screen to select Video/Music etc
Now downloading the 1.0.3a to see if it works with that
Anyone else having this problem?
OK it works on 1.0.3a, odd all the sameLast edited by astral69; 21 June 2014, 14:49.
Originally posted by BTR11 View PostYou have to gain superuser permission first, so first command to run is:
su
So, I flashed Wasser's 3.1a rom without any problems. I'm trying now to flash one of the Overclocked kernels.
I downloaded it and changed its name to "kernel.img" and saved it onto a blank SD card, in the root directory.
After inserting the SDCard into the X7, I opened the "Android Terminal Emulator" app and then typed out the commands listed below:
su
export PATH=/data/local/bin:$PATH
All I got was a "error opening /sdcard/kernel.imgfailed with error: -1"
Any help would be greatly appreciated.
Thanks.
There are currently 1830 users online. 1 members and 1829 guests.
