Originally posted by tode View PostThank you Wasser!
I test your ROM asap.
Did you used the libmedia.so patched by stafstrom, to enable pass through in XBMC?
Thanks,
tode
Originally posted by ptiper21 View Postwasser, what about usb ports, cameras, air keyboards like pro f10
etc... does this image support them?
i don't have the minix x7 hardware to test. so please test it and give me the feedbacks!
thanks
Originally posted by roolmapool View PostThx Wasser for KK rom !
Someone to report if ethernet issue fixed?
Regards,
Wasser,
Ethernet still not working, still says unconnected. Wifi is great, writing from it actually.
I did notice something strange at boot, only once, dont know if you did that or a teaser whats waitin for us. just a split second before the boot animation starts, an image with Google TV showed up. I rebooted loads of times to see it, it was only a single occasion and caught me while looking away.
Edit: i see the rom uses Dalvik by defualt, since i am not aware of the diff. between Dalvik and ART, i assume youve reverted it back. Is ART any benefitial for us?
Re: KiKat-4.4.2 for Minix X7
Sent from my Nexus 5 using Tapatalk
To bad... i use ethernet only.
Do you test videos playing...? Judders or 100% smooth?
About art, i use it with my nexus 5... no visible performance, but better autonomy.. but Minix don't care lol
Dalvik is the default by 4.4.2. As i know ART doesn't work well some some devices. But you can change it if you want
Originally posted by Pluto View PostTried ART, did have a few FC's with it, turned it back off.
I have never aided with logs to a dev before, can you please enlighten me how to do that?
PS, the rom feels a bit like Strauzos nexus in cosmetics, does this use the tablet SDK as well?
and send me the dmesg.log fiile
this rom is based on kikat-4,4,2 source which was uploaded at the begin this year.
Originally posted by wasser View Postit's easy, just do: adb shell dmesg > dmesg.log
i did i straight from the Android Terminal Emulator, should be the same right?
ps, boy is web browsing better in KitKat, even Chrome runs smoother.Attached Files
Originally posted by Pluto View Posti did i straight from the Android Terminal Emulator, should be the same right?
Could someone please post the dmesg.log with stock kernel and ethernet enable?
could it be that minix x7 uses another ethernet driver!
thanks
Also, no need anymore for Null Keyboard, recognized as Physical Keyboard, and i guess thats probably why i lost some features. The soft keyboard wont annoy you anymore.
Wasser, the Logitech K400 has three volume buttons, Mute, Decrease and Increase, located at F10, F11 and F12. I was wrong when i noticed it before since i did not put much time on it. What it seems to do is have just one option on the sound slider, its either absoluitely off or fully on, with just one click. As if the steps were removed, it used to be every click resulting in -+5% of sound, now its 100%. And if it crossed your eyes before, there is no sound output from the Headphone jack, and i mainly use that for my old HiFi AVR.
There are currently 1593 users online. 0 members and 1593 guests.
