Sent from my Nexus 5 using Tapatalk
Guest
see dmesg attached
Bluetooth works and all volume ranges w/bluetooth
HDMI output still broken where only get 100% volume with vol+, or 0% volume with vol-, mute doesn't work. If it helps when you press vol- it goes to 0%, then if you press vol- again it goes to mute.
Also noticed that when you flash everything from scratch, it starts as 720p/50hz. Not sure if it isn't recognizing the monitor correctly or if that is just a default you set in your img.
I need to checkout now for a bit.Attached Files
thanks
Guest
.so?
Hi wasser,
When you added the support for the remote - what did you add? Driver for infrared + file for the keymap?
My questions is because Minix has added an A2 airmouse driver to the original firmware, and this is causing conflicts with other remotes (Mele F10 Pro or Logitech K520)
I'm just wondering what I need to edit to make sure I can add support for another remote.
Might even be possible to add something to the 'settings ' section where you can choose what remote you have - and that it loads that driver so there is no conflicts anymore (no shutdowns).
Is this a kernel configuration or are you sideloading drivers ?
2 you need both
Guest
3.5mm headphone jack doesn't work. When plugged into headphone jack with my earbuds, the sound still comes out of the hdmi cable to the monitor and out monitor speakers.
Guest
Originally posted by wasser View Post1 yes, driver for infared and keymap
2 you need both
So I will find a good keymap for my remote (Mele F10 Pro) and I will try this with your firmeware later. Or I can make myself one based on Generic.kl?
Maybe I can extract the A2 airmouse keymap from my Finless 1.8 installation and upload it here so you can provide it with the next firmware as an option.
Is the driver for airmouses the generic usb driver for keyboard and mouse or are there specific drivers for each remote?
Originally posted by soyrme View Post3.5mm headphone jack doesn't work. When plugged into headphone jack with my earbuds, the sound still comes out of the hdmi cable to the monitor and out monitor speakers.
Pluto, or volunteer: could you please figure out in which kernel 3.5mm headphone jack and volume +/- works? it will help me a lot!
thanks
2 i think it's generic usb driver for keyboard and mouse
Wasser, the kernel u fixed the sound buttons was the version that had sound on the 3.5mm jack.
Will test the new Kernel as soon as im home.
Originally posted by Pluto View PostThats always like that, all roms have this, u have to mute the TV, it will output from both sources.
thanks
Re: KiKat-4.4.2 for Minix X7
Originally posted by wasser View Postnew kernel uploaded, please test again!
thanks
short info how easy to flash kernel:
1 lauch terminal
2 su
3 flash_image kernel kernel.img
4 reboot
http://www.freak-tab.de/wasser/kerne...7-110114-2.zip
Originally posted by queonda View PostWhen doing, do you loose everything? If so, there a way to backup apps and settings?
There are currently 1561 users online. 0 members and 1561 guests.
