Originally posted by gatekeeper179 View PostI use Antutu benchmark latest version and my results are below :
Note : I have never had any streaming Video 1080 HD lag or drop outs on XBMC Beta 1 or Beyond XBMC (5g wifi), and never had any crashes or random reboots on any of the listed roms above.
I have two Minix x7 boxes and Logitech K400r keyboards on both.
Hope this helps
Gatekeeper179
The most "acceptable" for me is the 008 fw rooted (kasty one), using MX Player and Minix XBMC. Although I would like to see justXBMC working (I mean perfectly, it mostly does..) since it is the only version that I found one could scroll using the air mouse.
On the other hand, it is true that I am not hunting a high Antutu score but preferably a real smooth 1080p playback. After all, the box of the Minix states "Media Hub" on it.
Originally posted by wasser View Postnew kernel uploaded, please test again!
thanks
short info how easy to flash kernel:
1 lauch terminal
2 su
3 flash_image kernel kernel.img
4 reboot
Ok, for some reason I cannot do from sd card flash_image kernel /sdcard/kernel.img
Where do I need to place the kernel.img using flash_image kernel kernel.img ??
Originally posted by queonda View PostI cannot believe my sd card has to be inserted upside down.Ok, for some reason I cannot do from sd card flash_image kernel /sdcard/kernel.img
Originally posted by wasser View Postflash_image in 0.92 is broken, therefore you cannot flash it. It will be fixed in next release.
0.92-4.4.2 and then 7-110114-2
or just 110114-2
I was only trying to install 110114-2 image.
Originally posted by adx7 View PostYou're lucky! Tried all this and I still get micro-freezes in 1080p playing, using what you mentioned.
I dont know if advancedsettings.xml is needed in beyond xbmc beta 1, but I put mine in from xbmc beta 2 and so far it all runs fine on streaming 1080 HD over 5g wifi with no micro freezes etc.
Gatekeeper179
Guest
FYI, I found a problem with using a vpn over wifi. I can define a vpn in Settings/More/VPN and connect properly using that vpn thru ethernet. But when I disconnect ethernet, and connect wifi and try to connect using the same vpn connection definition, it will not connect.
Where do I need to place the kernel.img using flash_image kernel kernel.img ??Originally posted by wasser View Postflash_image in 0.92 is broken, therefore you cannot flash it. It will be fixed in next release.Originally posted by queonda View Postk. Thanks! This is my 1st time trying to do this way. After you fix it should I need to do both of them or only one of them?
or just 110114-2
Originally posted by queonda View PostMy found out the address to the sdcard is /mnt/external_sd/kernel.img After you put flash_image kernel /mnt/external_sd/kernel.img and enter in the terminal is something suppose to happen? Please give me some guidence. Wasser mentioned .92 is broken. but there are 2 links on the 1st page. Does both need to be installed or only one? I been reading some people having issues with x7 ethernet and bluetooth issues and throught that what the 110114-2 is for.
ps, flash_image has worked flawlessly for me, mind you that i use the Download folder for nearly everything just for being a favorite shortcut for apps.
Code:su flash_image kernel sdcard/Download/kernel.img reboot
Guest
Originally posted by soyrme View PostFYI, I found a problem with using a vpn over wifi. I can define a vpn in Settings/More/VPN and connect properly using that vpn thru ethernet. But when I disconnect ethernet, and connect wifi and try to connect using the same vpn connection definition, it will not connect.
Guest
Anyone have hbo go and can test if they are getting bad stutter in playback as well using 4.4.2? I have no problem on minix stock 006,007e,008 and finless 1.6-1.8 roms but once I install on kitkat, I get bad stuttering either immediately or after a minute or so. I have tried on both Ethernet and wifi and have 25Mbps download speed and tested many other streaming apps but HBO Go and Showtime (hdmi hack from xda forum) both stutter badly. Any thoughts?
There are currently 2249 users online. 2 members and 2247 guests.
