I reflashed holding down power button and it worked. Very Grateful. Thanks a lot. Kevin
Anyone have any joy getting a droidmote like app working between this Rom and another device?
Been playing round with sixaxis as well, it's hit and miss trying to get it to go, sometimes it starts fine, most the time it doesn't fully start. Even using the force stop fix on the Bluetooth share.
Originally posted by wasser View Postplease try this new kernel, it supports stock ir-remote
http://www.freak-tab.de/wasser/kernel-minix-x7-160114.zip
thanks for the great work.
Originally posted by queonda View PostWhat Kernel version is the latest? I'm seeing 3.0.36+ looking at about in the settings.Is that what I should be looking at or should I be looking at the date and time also?
Originally posted by dk0r View Postwasser, should we expect to see support for the minix neo a2 remote? thanks for the great work.
Originally posted by wasser View Postdoes the neo a2 remote not work in the 0.92? Could you please add more infos ?thanks
The A2 remote does work with this rom, however not all buttons do. In my case the tabs (switch apps), options and apps buttons are not working. For this reason, I have to keep the bottom bar on top.
Until now I have been using stock-roms and Finless 1.8. Finless 1.8 worked just fine, including 1080p video playback. (using oc kernels).
Yesterday I flashed Wassers KitKat rom with the kernel from 2014-01-16. Sorry if this is a stupid question, but how do I use/change the OC options? Tried apps lik set-CPU but this won't let me adjust memory and GPU settings.
With default settings, 1080p playback is stuttering unfortunately.
Thanks very much in advance for your help!!!
Originally posted by gjvk70 View PostTried apps lik set-CPU but this won't let me adjust memory and GPU settings.
Which player are you using for video playback? I'm also using the oc'd kernel but even with the original one all 1080p videos played perfectly smoothly on my system.
Originally posted by Molle View PostDDR speed is locked to 720 and can not be adjusted. Also, there are to my knowledge no apps for changing the GPU speed. You can always ask Wasser for a more heavily oc'd kernel (DDR800, GPU798).
Which player are you using for video playback? Even with the original kernel all 1080p videos played perfectly smoothly on my system.
Thanks or your quick reply! I tried Minix XBMC (latest version which played very well with Finless 1.8) and Beyond XBMC.
If things are ok with you, I must have done something wrong. Also tried different HDMI settings (1080/24/50/60). Did't make a difference.
@Wasser: Do you think it is an option to create a kernel with the settings Molle mentioned?
Regards,
Gerard
Originally posted by gjvk70 View PostFirst of all, thanks for this great rom. Good to see Kitkat is making its way to the X7...
Download this file http://flumpster.lolcakes.com/androi...oduct_7a18.zip and extract it.
Place the Vendor_0c40_Product_7a18.kl in system/usr/keylayout and set permissions RW R R (644).
Restart the machine and see if any of the buttons work.To Infinity and Beyond.... XBMC
Originally posted by gjvk70 View PostI tried Minix XBMC (latest version which played very well with Finless 1.8) and Beyond XBMC.
Originally posted by Molle View PostMINIX XBMC won't work on this rom (all hw acceleration is disabled). I'm using Beyond XBMC myself and have no problems with 1080p videos. Try the stock video player. If you get stutter on that, there is some deeper issue at play.
I will report back.
Reinstalled Beyond XBMC and this is working fine now. Thanks for pointing me in te right direction.
Tried to copy the extracted file to the keylayout-folder, but this resulted in an error (read only file system). I am kind of a newby on android, so I will try to figure this out and get back to you.
ES File Explorer did not have root access. Used Solid Explorer instead.
Unfortunately, the device won't boot anymore :-(. Afraid I will have to start again from scratch. Think I call it a day...Last edited by gjvk70; 19 January 2014, 22:01.
There are currently 2697 users online. 2 members and 2695 guests.
