How can we add the audio manager, what do you need for that ? Can I help ?
Guest
Originally posted by Flumpster View PostI do not have this rom but go to settings, about tablet and click the build number 7 times quickly, this will enable developer mode and you can then turn on USB debugging.
Originally posted by DeliriumNL View PostI fixed my SD card, just had to reformat it after going back to 4.2.2,
Guest
Originally posted by wasser View Postas is metioned in last post the codes for audio manager doesn't exist in kikat-4.4.2. We have to code this missing part in 4.4.2 sdk. Sure you can help me. Fisrt you have to download the 4.4.2 sdk and try to add the codes for the missing part and send me the patch.
Wasser please could you upload here for me :
sensors.rk30board.so
from the Kitkat rom? I don't have it currently installed so I can not extract it. It comes from SDK yes? not from Minix?
Thank you.
Originally posted by DeliriumNL View PostI will try this later. (limited on time right now)
Thank you.
Guest
Originally posted by wasser View Posti uploaded sensors.rk30board.so from my kikat firmware. It's built from 4.4.2 sdk. You can download it from
http://www.freak-tab.de/wasser/sensors.rk30board.so
Guest
Any idea what the purpose of sensors.goldfish.so is?
I could not find sensors.rk30board.so implemented in my current rom.
But it has the same as sensors.default.so -> i gues that's the name if you want it in use?
UPDATE: the sensors.rk30board.so from your 4.4.2 sdk is compatible with 4.2.2 romsLast edited by Guest; 26 January 2014, 20:16.
Rom Weekend
I have gone through 4 roms this weekend. Starting with the Minix 009 (Bad stuttering Video in XBMC)
Tried the other KitKat but i really like how snappy this one is. Using the Newest nightly build of Minix and Minixhub.
Hoping for the best.
My best rom to date was Quickshot (Both versions) but had random crashes with it.
I like the Shutoff features in Quickshot and Minix versions though. I can choose to reboot in Both or shutdown. Minix XBMC has that nice feature built into it also.
IR remote
update on the IR remote. i found that the rom now responds to the remote of K-R42 and clones (most probably because the rom source is for those). I guess this is a good thing because minix x7 remote functionality is crappier than the other ones. Since i dont have a kr42, the hard part is to set it up in harmony remote.
Originally posted by canuckfan59 View PostI have gone through 4 roms this weekend. Starting with the Minix 009 (Bad stuttering Video in XBMC)
Originally posted by canuckfan59 View PostI can only seem to mnt one USB drive in this version? I have two I need mounted for my Movies in XBMC though.. Anyone else experience this?
IR remote not supported
Originally posted by wasser View Posthave you tried this kernel? http://www.freak-tab.de/wasser/kernel-neox7-1080p.zip
this kernel supports stock ir remote and it should be stable as the the kernel-minix-x7-110114-2.zip.
could someone reproduce this issue too?
I can get to the welcome/language screen, but that is it
A shame as the reports sound to promising
No support for the other option I have whcih is the RK Remote phone app
Thanks for all the effort everyone is putting in
I will be monitoring progress and trying again later
So back to Finless 1.8 for nowLast edited by astral69; 27 January 2014, 13:56.
@Wasser
The parameters for the mali.ko module seem very outdated in 'init.rk30board.rc'. To test values which would better reflect the GPU frequencies available in the current kernel config I created a boot.img with the following entry:
Code:insmod /system/lib/modules/mali.ko mali_dvfs=133,200,266,300,400,600,798 mali_init_clock=400
Code:<4>[ 13.628742] Mali: Mali400 inside of rk3188! <4>[ 13.628782] Mali: mali freq table num : 2 <4>[ 13.628811] Mali: mali freq table :Mali: 384,Mali: 594,Mali: <4>[ 13.628885] Mali: init mali clock success <4>[ 13.657771] Mali: Mali device driver loaded
There are currently 2679 users online. 1 members and 2678 guests.
