Originally posted by Cantenna View PostThey are in this thread, I'm using 4gig. Have to re-flash rom and all thought to apply. Use titanium to backup and restore
900Supersport
freaktab developer
Originally posted by 900supersport View Post
So far seems to be a great ROM. Really impressed. However I'm having a similar problem that I had on finless 1.8 with oc kernel set at 1800 max . when antutu gets to Testing CPU Float Performance at around 27% using either version of Antutu it force closes or gives me the message that antutu stopped responding... I had this problem before and therefore can't run a full antutu test with the full of kernel supplied. If I use no frills and set Max at 1608 it will complete test. This is the only app so far that I can remember that thus happens to. Other than that with cpu Max set at 1608 I am getting 19108 ATM but really want to know why this is happening, I must know what antutu score I'd be getting with Max set at 1800. If I remember correctly I had to set no frills at 1704 or whatever it is with the 1800 oc kernel on finless but we don't have that option with this kernel. Someone help me with this! Molle my man! How you getting that score again? And antutu completes test with you?! Like I day it force closes @ 1800mhz although it still shows as testing in taskbar it doesn't complete the test. Thanks
Sent from my GT-I9505 using Tapatalk
Originally posted by Smokez View PostSo far seems to be a great ROM. Really impressed. However I'm having a similar problem that I had on finless 1.8 with oc kernel set at 1800 max . when antutu gets to Testing CPU Float Performance at around 27% using either version of Antutu it force closes or gives me the message that antutu stopped responding... I had this problem before and therefore can't run a full antutu test with the full of kernel supplied. If I use no frills and set Max at 1608 it will complete test. This is the only app so far that I can remember that thus happens to. Other than that with cpu Max set at 1608 I am getting 19108 ATM but really want to know why this is happening, I must know what antutu score I'd be getting with Max set at 1800. If I remember correctly I had to set no frills at 1704 or whatever it is with the 1800 oc kernel on finless but we don't have that option with this kernel. Someone help me with this! Molle my man! How you getting that score again? And antutu completes test with you?! Like I day it force closes @ 1800mhz although it still shows as testing in taskbar it doesn't complete the test. Thanks
I get 19607 on Antutu with OC Kernel
Just tested again using fux clock settings/changes and got 19667
Originally posted by Smokez View PostMolle my man! How you getting that score again? And antutu completes test with you?! Like I day it force closes @ 1800mhz although it still shows as testing in taskbar it doesn't complete the test.
When I was still on JB-based ROMs and ran self-built kernels, I found out my X7 could pass AnTuTu with 1920/800/798 kernels.
Originally posted by Daz View PostFirst thanks Wasser for your efforts. Ive been using this for sometime and by far the best rom ive tried to date.
Ive since ran out of app space. Is there any other parameter files I can use... or parhaps an alternative solution?
Originally posted by queonda View Post[ATTACH]5136[/ATTACH] trying to upgrade the kernel through reboot. Doenst seem to be working. See pic. Please advise.
Sent from my HTC PH39100 using Tapatalk
You should please use flash_image or flashtool which is included in firmware zipfile.
Originally posted by saddas View PostHi, Wasser!
When you plan to post your next KitKat release?
- Multi-disk mounting
- webcam
- volume +/-, mute
volume +/-, mute is already fixed, but the rest not yet. I will release it when these 3 issues are fixed!
Guest
There are currently 2631 users online. 1 members and 2630 guests.
