Guest
Originally posted by wasser View Post
Guest
Originally posted by wasser View PostHi Smokez,
i even uploaded new oc kernels.
CPU: 1008/1200/1416/1608/1704/1800, DDR:720, GPU: 133/200/266/300/400/600, 1080P
kernel-ddr720-cpu1800h-1080p
CPU: 1008/1200/1416/1608/1704/1800, DDR:720, GPU: 133/200/266/300/400/600, 720P
kernel-ddr720-cpu1800h-720p
Have fun!
wasser
Thanks.
Re: KitKat-4.4.2 for Minix X7
Have fun!
wasser
Sent from my GT-I9505 using Tapatalk
Have fun!
wasser
OK so really pleased with results on new kernels. However, best results achieved with 720p as requested but I have lost the taskbar so cannot back click or open up multi tasking etc and now my menus and defaults apps are located vertically down the left hand side and have different search widgets etc on home screen. Was this intentional as it was not the case when I tried the 1080p version. One thing I will say is antutu scores are great - back at 20300
Originally posted by Smokez View PostOK so really pleased with results on new kernels. However, best results achieved with 720p as requested but I have lost the taskbar so cannot back click or open up multi tasking etc and now my menus and defaults apps are located vertically down the left hand side and have different search widgets etc on home screen. Was this intentional as it was not the case when I tried the 1080p version. One thing I will say is antutu scores are great - back at 20300
ro.sf.lcd_density=240 -> ro.sf.lcd_density=160
Originally posted by Smokez View PostOkay thanks. I have build.prop editor but really need talking through the process. As I have tried once before but couldn't seem to edit any files
Originally posted by Smokez View PostScrap that managed to edit it successfully. Thanks, should have tried first! since reboot and before changing this I keep getting the msg 'unfortunately system.ui stopped reaponding constantly. Any ideas?
issues booting up
Hi all. Firstly - amazing rom wasser!!
Just wondering if anyone has experienced the system not booting properly.
I had this rom running fine for about 4 days but today I cant get past the boot image - the four colour kitkat startup animation. It just keeps going with the animation and never loads to the android 'desktop'.
I had this happened one other time with the 'other' kitkat rom. I had to re-flash to get it working again.
I'm hoping there is an easy fix that doesnt require starting from scratch each time.
Thanks again for all the great work!!
Originally posted by wasser View Postplease tell me which oc GPU/DDR, i can build some oc kernels for you.
the donation button is added ;-)
Donation Sent (Unique Transaction ID # 1ST827519F3810253)
cpu1704h/cpu1800h gpu798h ddr800 1080P
cpu1704h/cpu1800h gpu798h ddr720 1080P
cpu1704h/cpu1800h gpu600h ddr720 1080P
cpu1704h/cpu1800h gpu600h ddr800 1080P
Thank you Wasser.
Best Regards,Last edited by Cantenna; 05 February 2014, 07:21.
Originally posted by Smokez View Postsince reboot and before changing this I keep getting the msg 'unfortunately system.ui stopped reaponding constantly. Any ideas?
There are currently 2656 users online. 1 members and 2655 guests.
