Sent from my GT-I9505 using Tapatalk
Re: KitKat-4.4.2 for Minix X7
Originally posted by georget View PostHi lachyzee,
When I went to the NFL link above with my Minix X7 running Wassers 4.4.2 KitKat firmware, The Google Play store says "Your device isn't compatabile with this version"
The KitKat firmware is spoofing a Samsung Galazy S3. model GT-I9300
Sorry, I tried.
George
We still have 6 months to go in order to fix it. ☺
Sent from my Nexus 7 using Tapatalk
Originally posted by Phycopat View PostHas been following this rom on the sideline for some time now..
Would like to know what ppl think about it? Is It ok for all time use, or does it still have bugs?
And about the audio, still no passthrough right?
Is It there somehow, or a no go?
Seems to me that video and game is running good?
An update on whats working and not would be so nice :-D
Video playback is fantastic. Picture quality is stunning and I haven't had any crashes.
Originally posted by georget View PostI'm using a TP-link TL-WR541G. It's an older router, but it works well. I went into its settings for WAN and the only setting for MTU is to change the size. I have it set on the default of 1500
I tested the Minix with wifi and Bluetooth disabled. Same thing.
I have a K-R42 with the same KitKat 4.4.2 kernel and firmware installed and I see the same Ethernet behaviour.
It would be very interesting if you do NOT see this behaviour. It is super easy to test...
1) Just boot the Minix up without the Ethernet cable connected
2) go into Android settings for ethernet and watch the status.
3) plug in the Ethernet cable
Did the Minix "connect" or does it still say "unconnected"?
I have to physically remove the cable and plug back in, or toggle the check box to make the Minix "connect"
If no one else sees this, then it must be me.
Originally posted by Pluto View PostAlthough the TP Links are very buggy devices, the case here is your box as it seems. I havent had an ethernet problem ever since the 14th january kernel release, and ethernet can be hot-plugged without any problem.
Thanks for taking the time to do the ethernet experiment. I don't believe it is my box since I get the same results on the Minix X7 and the K-R42 running the same firmware and Kernel. If YOU booted your Minix without ethernet cable connected, then plugged it in and the Minix "connected", then it must be working correctly, and the problem is on my side.
Of course my ethernet works great once it is connected. I can hot plug it all day and it will always reconnect. The problem is only seen on the first boot with cable disconnected.
Wasser has made this amazing Firmware for us. If there are any issues that we can bring to his attention before he releases the next version, the firmware gets that much closer to being perfect.
Originally posted by lachyzee View PostHmm thanks. That is odd.
I tried one last experiment by going into the build.prop editor and changing the Model name from "GT-I9300" to "rk31sdk". No luck. I still get the same message "Your device isn't compatible with this version".
old mk802iv running KitKat
Just had to say thank you having fun testing this ROM on mk802iv old WiFi with k-r42 kernel which I tried to use overclockomatic on it but no luck, BT doesn't work but the WiFi is the most stable I've had since NeOs Cr 1.5 for old mk802iv and just had to give you the good news and beyond xbmc keeps me happy antutu 17369
Let's see if I can finally post
Originally posted by Cantenna View PostOnly thing I'd like to see improved is 1080p xbmc playback; its jittery. But, MX player does the job fine.
xbmc-20140214-18cebf0-master-armeabi-v7a.apk
SPDIF
Originally posted by wasser View Postspdif passthrough should work on this rom, hdmi passthrough still doesn't work
but I do not get any sound coming through on spdif or hdmi
No Sound options for selecting output either......
Has anyone used this kernal successfully?Last edited by astral69; 16 February 2014, 12:02.
Originally posted by wasser View Postvolume issue is already fixed. It will be included in next release
I found another problem.
- I use SoundAbout and AUX. If I watch youtube Videos per App the sound sometimes go off and the App say there is no Internet.
If I choose another Video it plays but if I want sound I have to reload SoundAbout.
- I use xposed GravityBox (KK). If I click 'Schnelleinstellung Anpassen' (to odrer the quicksettings) it crashes
and if I used Advanced PowerMenu and choose Soft Reboot the System Ui crashs after Booting
Could it be true that my TP Link WR841 crashs if I use my Minix x7? Sometimes I only have low Internet speed and I have to reconnet to the TP Link Switch.
Originally posted by phjanderson View PostAny clue how what would have to be done to get USB cameras working?
NB - Can this ROM be installed easily in some way through CWM? Thanks
There are currently 5332 users online. 2 members and 5330 guests.
