DTS on SPDIF passthrough (Wasser KK 1.0.2) works flawless for me, but I have the hacked libmedia.so.
Guest
Wasser:
Testing Wasser XBMC results.
Video : 15mbit/sec 1080p MKV (13gb) file plays smooth with 8 dropped frames in 30 minutes.
Audio soundtrack (downmixed DTS to stereo) at 1500kbps has an audio quality of 99%, with frequent 'Pops', and 'crackels'.
Music : high bitrate FLAC - plays great without issues.
ROM: QuickShot 3
ROM: QuickShot 3
It would be great if you could test wasser xbmc on wasser firmware 1.0.2 and post feedbacks!
thanks
Originally posted by dwane3 View Postsorry,for JB firmware quckshot v.2 this compatible?
Originally posted by Lachty View PostWasser do you know how hack flash player? I need play flash video in fullscreen when is systembar hide. Thx.
Originally posted by saddas View PostHi, Wasser!
I have tried your XBMC on wasser firmware 1.0.2. It's working good for me.
Could you add russian keybord into Wasser XBMC?
Thanks!!!
Originally posted by arhim View Postwasser, dear friend, share init.d daemon example for CIFS mounting of windows sharing
#!/system/bin/sh
IP=192.168.0.100
CIFS_DIR=/mnt/cifs
mount -o remount,rw /
mkdir -m 755 $CIFS_DIR
mount -o remount,ro /
mount -t cifs //$IP/test $CIFS_DIR -o unc=\\\\$IP\\test,username=android,password=test
oc kernels
Hi all,
i uploaded some oc kernels-1080p. Please take a look at the first post for more infos.
For miximal stability, i don't recomment to use the oc kernels. 1080p video playback works smoothly with the standard kernel with ddr400/cpu1608/gpu600 in my 1.0.2 firmware!
Enjoy,
wasser
Thanks! Great so far!
Hi wasser,
Great rom by the way - coming from QuickShot v2 for the X7 installed on the X7mini - this is just so smooth! I installed your XBMC as well and so far everything works well, include 5.1 audio passthrough.
Netflix, spotify, sirius, crackle, youtube all work well. I also use TV Launcher. More feedback after I've put it through the ringer.
Thanks again!
wasser kitkat 1.0.2 installed on an X7 Mini
wasser xbmc
default kernel from ROM
Originally posted by wasser View Postplease try this script, and please let me know if it works for you. I haven't test this script because i only use nfs.
#!/system/bin/sh
IP=192.168.0.100
CIFS_DIR=/mnt/cifs
i attached my dmesgdmesg.txt
i tested my windows 7 share from linux settopbox and it is ok, then a tested it at android 2.3 from my old smartphone - and it is ok. at 0.92 firmware it is ok too, but now at 1.0.2 - it`s not workingLast edited by arhim; 25 May 2014, 06:33.
There are currently 2450 users online. 0 members and 2450 guests.
