wasser
I install wasser 1.0.1. I am running on stock kernel. How I can upgrade kernel to version 3?
When I connect USB disk. How I can go to /mnt/usb_storage in ES File explorer?
Flash player work only in Dolphin with "Flash Player amended" from here: http://forum.xda-developers.com/show....php?t=1774336Last edited by Lachty; 17 May 2014, 14:21.
Originally posted by Lachty View PostI install wasser 1.0.1. I am running on stock kernel. How I can upgrade kernel to version 3?
people, why are you so lazy?
install pure kitkat version of flash from real men - it is recompeled version for 4.4.2 android only
try it with mozilla firefox - 100% tested with Firefox
Originally posted by Lachty View PostFlash player with Boat browser does not work. Do anybody know how i can repair it?
install kitkat flash player and try it with Firefox
I've ran into some issues installing v1.0.1.
First, it would find the X7, wipe-it out and reboot and wait for the loader, and for some reason the X7 boots ordinarily but with not ROM inside ... So i felt it needed my interruption in the flash process. First, the moment it shows that it is waiting for the loader to start after it's done with wiping, i immediately restart it back to recovery mode, and the flash process begins downloading the ROM (and checking it right after)
It seems to try to boot, but something is wrong:
it doesnt even make it to a spin, and it shuts down (not reboot)
Wasser, any chance to make a multiple file download as well, i really am not a fan of the batch tool.
Originally posted by arhim View Post
Originally posted by Lachty View Post#1180 to markwerline: What kernel do you use?
I also am back to the sound being set to airmouse A2 on reboot again as well as the microphone input doesn't work.
but the crash is no more and its very stable.
Originally posted by Lachty View PostHow I can flash new kernel? I can not load it in RKBatchTool.
1 lauch terminal application in android (download from the play store any terminal program)
--the following are commands you type in terminal--
2 "su" (it might ask for su permissions hit grant)
3 "flash_image kernel kernel.img" (make sure to have copied the kernel.img file to /sdcard directory first)
4 "reboot" (go ahead and type reboot in the terminal to reboot)
hope this helps you as it did for me
Shut down
Hi Wasser,
I have sudden shut downs after Homescreen is shown within the first 2 Minutes.
The screen freezes and shows lines. Before the freeze I can open the settings or an app.
I have flashed the rom now 3 times (and downloaded it freshly every time), but it's always like this
Does anyone has the same issue and fixed it already? Thank you!
or... you can wait for 1.0.2 which wasser stated will have this fixed in it.
There are currently 2651 users online. 1 members and 2650 guests.
