Originally posted by hd0120 View PostWasser, can you please show me what to do with the hacked libmedia.so file? Thank you very much.
1.open EsFile explorer/enable root acces and click on it/ change permissions to rw
2.overiride the libmedia.so file from system/lib with the new one. After you'll override the file the X7 will semi reboot. Don't worry, it's fine.
3.go back to root access-permissions and change them back as they initially where.
Use a custom XBMC with passthrough enabled. You'll find a link for it a few posts above.
Will this work with HDMI to??
Can anyone test?
Originally posted by wasser View Post
Originally posted by strix View PostWill this work with HDMI to??
Can anyone test?Last edited by Kiralina; 20 May 2014, 20:40.
Originally posted by strix View PostThat is the same config i use. No sound for me to
The HDMI config was just for tests.It detects passthrough , when I try to move the volume bar with the minix remote it says passthrough detected, but no sound.
Re: KitKat-4.4.2 for Minix X7
Originally posted by danfozzy View PostFingers crossed that wasser can get this going for hdmi passthrough!
Take care with permissions of the filebif you copy it. It must have rw-r--r--
Leolas
Sent by my phone.
Enviado desde el telefono.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
ES File explorer problem
The latest version of ES file explorer grabs my ext USB disks and shows them on the side bar
but then rejects them as wrong format - must be FAT32 (they are NTFS)
I have had to regress the ES programme to the embedded version
and turn off wi-fi to stop updates
I also notice that the 1.0.1 kernel only allows one USB disk to be attached at a time
Originally posted by hexstudy View PostI have replaced a lib inside /system/lib the minix reboot but not restart.
I have restarted by cable (pull out & pull in) but nothing black screen
PS: Reflash 1.0.2, copied file lib... minix black screen ;(
Except that, mine shows "WASSER" before going to black screen.
2. Sound is not smooth while playing music. It is period broken.
There are currently 2739 users online. 1 members and 2738 guests.
