Originally posted by snoopspecial View PostHi wasser,
Great rom by the way - coming from QuickShot v2 for the X7 installed on the X7mini - this is just so smooth! I installed your XBMC as well and so far everything works well, include 5.1 audio passthrough.
Netflix, spotify, sirius, crackle, youtube all work well. I also use TV Launcher. More feedback after I've put it through the ringer.
Thanks again!
wasser kitkat 1.0.2 installed on an X7 Mini
wasser xbmc
default kernel from ROM
could you please test hls streaming if it works?
thanks
Originally posted by Decapper View Post@wasser
1080 oc description is correct link... Hyperlink points to 720
th download url for oc kernel is fixed.
thanks for imfo
Originally posted by arhim View Postit does not work
i attached my dmesg[ATTACH]6467[/ATTACH]
i tested my windows 7 share from linux settopbox and it is ok, then a tested it at android 2.3 from my old smartphone - and it is ok. at 0.92 firmware it is ok too, but now at 1.0.2 - it`s not working
could you please try one of new oc kernels if the cifs mout works for you?
please post the feedbacks
thanks
Originally posted by DeliriumNL View PostI did not test with Wasser kitkat, however Quickshot kitkat hls streaming does not work. (if that helps you)
i have tested some hls streamimg examples von apple and it seems to work for me, but i need someone to comfirm that.
But it seems noone really has interesse. It's a pity!
wasser
Guest
Originally posted by wasser View Postsorry, such report really doesn't help me, it's other firmware!
wasser
For example NPO : https://play.google.com/store/apps/d...tzendinggemist
Click something random, after 5-6 minutes it will stop playing, in the settings menu it says that the buffer is only 3.7 mb (too small).
This is a popular dutch app that lets you play back old episodes from tv. Good test case because a lot of apps use this method.
I have a lot of intresse in this, since I don't have a TV subscription this app is awesome if it would work
Try it, else I can install your rom and try it for you but I have to schedule it else my girlfriend gets a little upset with me removing the mediacenter
Others like Foxsport work this way too.
Guest
Or can you test with www.3fm.nl in the stock browser.
Click the "watch" (camera icon) feature to start visual radio stream.
On the mobile website, you should notice the stream will start with very very bad quality. After around 20-30 seconds, it will decide to switch to a better stream (which will hang forever in the non working situation).
Originally posted by Kiralina View PostDid you override the libmedia.so with the hacked one ?
DTS on SPDIF passthrough (Wasser KK 1.0.2) works flawless for me, but I have the hacked libmedia.so.
but still no DTS passthru with wasser xmbc
AC3 works fine in passthru on hdmi
Not a big deal as very little I have is dts
but would be nice to have working when I need it
Originally posted by wasser View Postcould you please try one of new oc kernels if the cifs mout works for you?
thanks
i asked to test my friend with his minix, but no luck too
tried with new busybox - not work too
tried connect to minix via SSH server - but no luck too, connection rejected after i entered password in terminal emulator (putty) at windows.
and i tried samba server at minix https://play.google.com/store/apps/d...pps.sambadroid - and it work.
at 0.92 version of firmware without multiuser SSH and CIFS work good.Last edited by arhim; 25 May 2014, 13:50.
Guest
try with new busybox , i will post result later.
Test with www.3fm.nl in the stock browser.
Thank you
Re: KitKat-4.4.2 for Minix X7
wasser
Sent from my Nexus 7 using Tapatalk
Originally posted by DeliriumNL View PostTry HlS smoothstreaming for me ? I am on QS3 rom today
Thank you
what are your writing to me?
There are currently 2681 users online. 1 members and 2680 guests.
