it is gone
Originally posted by astral69 View PostJust drag to the top centre of screen and when it goes red
it is gone
Originally posted by leerock79 View Postinstalled this on x7mini and its excellent!!
the only problem i cant live with, is that it doesnt get metadata fanart (movie covers) in video addons
is there a fix?
Originally posted by TechnicaL View PostAny news on the XMBC gothem S-PDIF out 5.1 support ?
Info, you need a xbmc 13 which supports passthrough!
I have a problem with connecting a bluetooth mouse. When I enable bluetooth and search for devices, my mouse shows up, but i'm unable to pair. When I select my bluetooth mouse, nothing happens.
I've had this issue also with previous versions. But it doesn't happen with other roms.
Any ideas ?
Originally posted by wasser View Posti even upload my libmedia.so hack could you please test if it works for you?
Info, you need a xbmc 13 which supports passthrough!Excellent work . I'm currently on your 1.0.2 FW with the new libmedia.so and XBMCZ Gotham on a 5.1 Logitech attached by optical cable to the X7. DTS passthrough works like a charm.
Thank you.Last edited by Kiralina; 20 May 2014, 16:09.
Wasser you got it!!
DTS and Dolby passthrought using SPDIF with your hacked libmedia.so work, but in my test Video got slowed a lot, it must be my xbmc version or my setup, I am not so good with xbmc. I will try it again.
You are the man!!! First you helped me with the RTL5616 (I didnt got to make it work in my kernels for X7) and now you got the libmedia.so hacked!! Great work!! I tried to patch the sdk sources but all my attempts was fails
Thanks a lot man!!
Originally posted by leolas View Post
Wasser you got it!!
Thanks a lot man!!
leolas
It works great with the libmedia.so hack.
There are currently 4389 users online. 1 members and 4388 guests.
