You can see that the subtitle is very smooth, but the picture is very pixelated!
Originally posted by lewys View PostNo, I don't.
I advice you to buy this little guy and forget about mouse. This simple air mouse is 93% perfect.
http://www.aliexpress.com/item/mini-...404212154.html
Air mouse is for hipsters and young'unsJokes aside, it's fun and stuff, but i cannot do serious work with a tool like that.
-= HELLO KITKAT =-
Originally posted by flemming View PostHehe, no chance i am going to wave some plastic gadget at my lovely machinery! I have used mouse and keyboard since my Commodore64 (33 years ago)
Originally posted by lewys View PostSure it's not for serious work, but if you use your minix only as multimedia device - it's perfect. And this airmouse almost as good as original LG TV airmouse, very sensitive and accurate.But it will seriously harm the size of the user group if this rom only is nice when you use airmouse. Even if a fix for normal mouse/keyboard is implemented, the air mouse will still work as usual, so it's a win/win situation!
-= HELLO KITKAT =-
Originally posted by saddas View PostWasser,
Could you in your 1.0.2 also fix the problem with Device Power LED?!?
In KitKat QUICKSHOT V3 by TheNitroTeam MINIX Neo X7 has device LED is working.
Link:
http://www.freaktab.com/showthread.p...m-MINIX-Neo-X7
This problem is already fixed in 1.0.0 release.
NEW kernel work good/
no crashes
usb hd webcam work good
youtube hd and IPTV FULL HD work clear
- but after flashing new kernel sound settings reseting after rebootagain. when i flashed release firmware 1.0.1 soundsetting bug was fixed.
please make NovaLauncher - the default launcher in the 1.0.2 release.
Originally posted by arhim View PostNEW kernel work good/
no crashes
- but after flashing new kernel sound setting reseting after rebootagain
please make NovaLauncher - the default launcher in the 1.0.2 release.-= HELLO KITKAT =-
no crashes
thanks for your feedback. i'm glad that the random crash is fixed.
I want to keep my firmware small and clean as i can. It's the reason why i don't want to add it.
Originally posted by wasser View Postthanks for your feedback. i'm glad that the random crash is fixed.
wasser, there is some reason why you spoof other device name in build.prop? I have to edit it manually to make the Airpin work.
@Wasser, your 1.0 ROM is really nice, fast, and smooth and i can mount NFS partitions!!!!
Few issues:
- HDMI passthrough with MX : Sometimes i loose sound, i have to qui MX player and launch again, and i have sound back.
- HDMI passthrough: when i am move & click A2 mouse on home destop, i hear "crack" sounds (notifications?)... it's very annoying!
- loose sound setting with last kernel. In stock kernel rom 1.0, i think it keep sound and not A2/Sage mouse.
Thanks for your hard work
Originally posted by roolmapool View Post@Wasser, your 1.0 ROM is really nice, fast, and smooth and i can mount NFS partitions!!!!
Few issues:
2. i think so, you can disable it in Setting->Sound
3. it works for me. Please plug your A2 airmouse to x7 device, reboot and then check it in sound device manager
wasser
Originally posted by flemming View PostI have this problem too
Also, please consider addressing the issue concerning autohide toolbar, that i described in post #1056
wasser
There are currently 3612 users online. 0 members and 3612 guests.
